Old 02-18-2007, 11:35 AM   #21 (permalink)
Vr4 Addict
Drives: 93 vr4
viva le greg is an unknown quantity at this point
Default Re: TEC front strut bar review
yea sorry for that !
93 green vr4
greddy type rs bov, AWS, yoko as430 tires,Newer TC, Free boost mod, UP short shifter, mushy intake, cross drilled rotors, BT ground wires, chrome ypipe (bling), royal purple everywheree
on its way to being installed:msd coils and wires, ngk coppers, 99 lifters, megan coilovers, 120k service, ips short dp, aem tru boost, walbro w/hotwire+install, adj ca's, tcase bracket, aem dryflow filter, pmp fmic
viva le greg is offline   Reply With Quote
Old 02-25-2007, 12:14 PM   #22 (permalink)
Dielectric's Avatar
Drives: 97 VR-4
Trader Rating: (6)
Dielectric is an unknown quantity at this point
Originally Posted by DennisVR97
Thanks for the extensive write-up. Of the bars on the market the TEC bar remains by far the most effective given it is not triangulated. Also, given what else is out there it is the highest quality ..... by far. A few points:
It is designed and tested in SolidWorks. Why there are gussets on the underside
There are a number of powder coated colors you can choose from.
The amount of material you removed was minimal. Are you sure your vehicle wasn't the cause? My bar dropped right in.
Although I have the front and rear bars, I'm not certain the front of the VR4 can benefit from a tower bar. Chassis design, under-bracing, bracing of the engine. Has anyone published data on tower deflection under load?
Yes, we're all looking to keep weight down, but 4.5 lbs in a 3600lb car ... that's too much? To potentially stiffen the front towers? How much weight would be reasonable?
The company owner/designer of the bar is responsive to comments/suggestions. Did you talk with him about your concerns/issues?
Yes, certainly not perfect. But compared to other bars for the 3S, this is an effective, quality piece. I suggest people attempt to compare side-by-side before making their decisions.
Don’t get me wrong, I am sure it’s one of the best available. However, I am very critical and expect a lot, so little things that most people don’t notice bug the hell out of me. That being said, the bar did fit upon initial installation, as I stated, it just didn’t fit like an OEM part. Although, my main issue is that if I torque the strut bolts way past the recommended torque setting the bar will noticeably contort. This makes me wonder about its effectiveness. Also, I suspect that milling the mounting points out of sold blocks is a major contributor to the cost. I believe the mounting points can be redesigned to be more effective and cheaper to produce. Just my 2 cents.
Dielectric is offline   Reply With Quote
Old 03-07-2007, 07:45 AM   #23 (permalink)
needforspeed's Avatar
needforspeed is an unknown quantity at this point
Originally Posted by J-Groove
Well, if it is just his car and not the TEC bar in general then I may have made a rash decision. Though the prices of the two are close so I don't feel to bad.
John that's a very nicely constructed sway bar you have installed. What brand and where did you purchase it. I just bought the cusco front and rear sway bar off ebay, hope it works good and not some knockoff.
needforspeed is offline   Reply With Quote
Old 03-07-2007, 08:38 AM   #24 (permalink)
J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7J-Groove Level 7
Thanks. It is a Carbing/ PitRoad M 3 point bar.
It is originally designed by Carbing but with design modifications done by Pitroad M. As the original by Carbing was supposably not a perfect fit, this one was basically a strait drop in.
I bought it from Ralli Art 3000GT on the board.
Old 05-16-2007, 12:51 AM   #25 (permalink)
Drives: 1992 eurospec 3000GT
TiberiusTribun is an unknown quantity at this point
Are you talking sway bars or strut bars here? Does Cusco even offer a front strut bar for 3000GT? All I ever see in the shops is the rear one...
TiberiusTribun is offline   Reply With Quote
Old 05-16-2007, 01:01 PM   #26 (permalink)
DennisVR97's Avatar
Drives: 1997 3000GT VR4
DennisVR97 is an unknown quantity at this point
I understand your position. However, a bar mounting OEM-like won't help accomplish its purpose. I agree, nothing should be contorting, but I'd have to ask again ...... was it the bar or your car. I've had mine off a number of times, it always drops back on and tightens with no issues. Has your car had frontal damage?
The next issue is .... IF you want something that actually works, what are the alternative bars out there? Cusco is for window-dressing only, and the Carbing ....... although triangulated (firewall mounted) will do little if you believe the towers deflect in the horizontal or longitudinal planes (inward or upward). It would need a section directly across the towers for inward deflection and it sits too low (fault of how low our firewall is) to stop the deflections around the horizontal plane. Its design seems best suited to stop rearward deflection, but even then it could benefit from triangulation with a section across the towers.
If any, the deflection(s) are probably in multiple planes, but does anyone know where the 3S is most vulnerable? Is there data somewhere other than SOTP data? That might help us with the decision on what is the most effective bar. Now ....... if TEC or Carbing combined the two designs, we might have something.
DennisVR97 is offline   Reply With Quote
Old 06-05-2008, 08:58 AM   #27 (permalink)
Let-luse's Avatar
Drives: 99VR4-93NA-CLS-H2
Trader Rating: (20)
Let-luse Level 3Let-luse Level 3Let-luse Level 3Let-luse Level 3
Another TEC owner (front and rear). Never had any fitment issue. The bar dropped right in the first time and I have taken it out multiple times since and never had to do much than knock it with my hand to take it out. Never noticed the bar contorting when tightening the bolts.
I also have the MAP sensor on top of the plenum on my car (99 VR-4) and didn't have any issues with it coming in contact with the bar.
So that makes me wonder too whether your car is out of spec. Are you the original owner? The reason I ask is because I had an issue with a racing dynamics strut bar that wouldn't fit on an E30 M3. Turned out to be that the distance between the strut towers was out of specs because of a previous accident.
another possibilty would be that the bar you got is from a defective batch or that it has been somehow damaged (bent).
Also from the picture below, I see that you have mounted the bolts holding the battery tie-down backwards. The threads should be going out not in so that they don't come in contact with the strut tower.
Reda/
Originally Posted by linchpinjoe View Post
Cuz 99s are cooler than 98s... :P Im not going to add fuel to this fire, so im just gunna go outside and hump my combat wing.
93 NA - 99 VR-4
Let-luse is offline   Reply With Quote
