Old 12-03-2004, 12:33 PM   #61 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (20)
mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7
Default Re: Review of the spec stage 3
Originally Posted by red3kgtvr4
Been there, done that. That's how I knew where the leak was. There's air rushing out of a hose or something right behind the clutch pedal inside the car. Seems to be coming out of the accordian-looking rubber boot. Any ideas how to get to the leak?
Read my post above yours. That's your problem. Flip that hose around and you'll be all set (as long as the check valve is still in that rubber hose).
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'93 3000GT VR4 (Project for 2009)
'91 3000GT VR4 (Only a shell of its former self)
mjannusch is offline   Reply With Quote
Old 10-18-2006, 02:21 PM   #62 (permalink)
ScottP is an unknown quantity at this point
I bought a Spec stage 3 plus Fidanza flywheel about 4 months ago. The car's making just under 400bhp, and was only used for weekend driving - no drag racing. Pulled away hard at lights - unusual for me, and the clutch plate welded itself to the flywheel ;-) Just had it apart, and the clutch is toast, so I think listing it as holding over 500lb ft is a bit optimistic ;-) It'd probably be ok if it was in a standard car. Good feel, light, but not much good for modest levels of tune, in my view...
ScottP is offline   Reply With Quote
Old 10-18-2006, 02:27 PM   #63 (permalink)
Banned from Classifieds
smokinvr-4's Avatar
Drives: Smokinvr4@hotmail
Trader Rating: (100)
smokinvr-4 is an unknown quantity at this point
a stage 3, or a stage 3+??
smokinvr-4 is offline   Reply With Quote
Old 10-19-2006, 01:15 PM   #64 (permalink)
It was a stage 3, I also had a Fidanza flywheel fitted at the same time. I guess the clutch managed around 2,000 miles before it was done.
Old 10-20-2006, 04:31 PM   #65 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7
When maTT had a SPEC stage 2 and DR650s it would hold anything under 22psi. At or above that it would spin. It would be fine if he droped the boost down though. He swapped it out for a SPEC 3 and it held (and still is holding) every thing he could through at it. It sounds like either you got a faulty clutch, a questionable install, or some thing leaking on it. I have heard of the pressure plate bolts backing out. That would cause the holding force of the clutch to be reduced. Did you check to see if that happened when you replaced it?
250 RWHP
Old 10-23-2006, 05:17 PM   #66 (permalink)
No, unfortunately due to my work at the moment I haven't had time to do much myself, so the garage that fitted the clutch also handled the replacement (ordered another clutch plate from 3sx). I thought the clutch felt too light, to be honest; no bite until right near the top of the pedal travel, and I'm pretty sure it was slipping after a lot of stop-start driving in the city for a couple of weeks before it failed.
Although the engine is capable of much more power - just had it rebuilt with all forged internals etc, I'll probably turn the boost back down to standard for now and see how it goes. If it cooks again, I'll put a standard clutch and the original flywheel back in. I'm trying to get the time to work on my trackday (kit) car, so I can live with losing 120bhp if it means it's reliable ;-)
Old 10-23-2006, 08:07 PM   #67 (permalink)
Gear Head
Top of the pedal? That isn't right. Either the disk got warped/bent during the install or the slave cylinder needed to be bled. I know from personal experience that if you rough house the tranny onto the engine, then your disk will get damaged, usually resulting in the clutch engauging/disengauging high in the pedal travel. If it doesn't grab in the middle of the pedal travel or close to it, then some thing is wrong.
Old 10-26-2006, 02:52 PM   #68 (permalink)
This one feels better, it grabs much earlier so hopefully should be fine now. I've turned off the EBC, so boost is back down to the standard 0.6 bar (feels slow now but at least it won't stress the clutch ;-) ).
Old 02-10-2008, 07:28 PM   #69 (permalink)
i got a snake in my boots
itzdjwonton's Avatar
Drives: Dodge Stealth Rt-tt
itzdjwonton is an unknown quantity at this point
alot of good things about this clutch! i'm gonna keep this clutch in mind when i put my new motor in
itzdjwonton is offline   Reply With Quote
