Old 06-29-2004, 09:13 PM   #51 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7
Default Re: Review of the spec stage 3
If you guys are breaking in engines then you may want to read through this thread. It has some pretty good info in it. It would be nice to have more members contribute data also.
engine breakin
250 RWHP
Old 06-30-2004, 06:06 PM   #52 (permalink)
awesomedave's Avatar
Drives: 94 Stealth R/T turbo
awesomedave is an unknown quantity at this point
The Stage III was a severe pain in the ass for me during break-in, too, and I was really thinking I should have gone with the Stage II...but then, magically, the break-in period was over, and after a few hard launches from 6000 rpm, it became extremely easy to use. There is light at the end of the tunnel. Don't worry.
Oh, and I'm getting my technique down pat with this thing now. I like to let it out until I'm barely moving, and then just let it out the rest of the way...the engine drops to like 300 rpm, but it's real smooth and quiet (no bucking if you do it right), and there is no unnecessary wear and tear on the clutch. Poifect.
First self-installed mod: Saner rear sway bar (the perfect mod to start with!)
Second self-installed mod: SPEC stage III carbon 6-puck clutch and RPS segmented flywheel (man that sucked)
Also:
Porterfield cryo-treated disc brakes
Porterfield R4-S carbon-kevlar pads
3SX SS brake lines
Motul 600 racing brake fluid
Tein S-Tech springs
Saner front sway bar
A'PEXi Power Intake
A'PEXi AVC-R
FINALLY!!
A brand new Mitsu shortblock with DR Stage III heads and 3SX WebCam street weld cams
Propane injection should be here any day
Now I just need to figure out what turbos are gonna go on...hmmm...
Looking for the wood and carpet (charcoal) from the hatch, if anyone's got one.
awesomedave is offline   Reply With Quote
Old 06-30-2004, 09:11 PM   #53 (permalink)
Just havin' fun!
red3kgtvr4's Avatar
Drives: Every chance I get!
red3kgtvr4 is an unknown quantity at this point
Well I sure am glad to hear that. I like lights at the end of tunnels! I think mine might be getting a bit better. Either that or I'm getting used to it - or both. It's still not as smooth as the stocker, but better than it was. I don't know if it's the clutch/fw, or the port & polished heads, or the bigger pistons, or just a combination of everything, but man does this car seem like it has a ton of torque now. Can't wait to get a couple more hundred miles on it (I'm at 330 now), and do some pulls. I need to recalibrate my EVC4. And I got a new Gtech pro - so I should be able to get a close reading on times and hp/torque.
red3kgtvr4 is offline   Reply With Quote
Old 06-30-2004, 09:33 PM   #54 (permalink)
Banned from Classifieds
smokinvr-4's Avatar
Drives: Smokinvr4@hotmail
Trader Rating: (100)
smokinvr-4 is an unknown quantity at this point
the heads make a HUGE difference IMO
smokinvr-4 is offline   Reply With Quote
Old 06-30-2004, 10:16 PM   #55 (permalink)
Just havin' fun!
red3kgtvr4's Avatar
These heads aren't from DR, they were done locally while the block was being bored. He did a good job, but they're not quite as opened up as Matt's.
I just remembered you're in Nebraska. My wife's mother lives in Pickrell. It's half way between Lincoln and the KS border. We're taking our 2 kids up there next month to stay for a few days. How far are you from there? Hmmm???
Old 12-01-2004, 02:19 AM   #56 (permalink)
18_SSX's Avatar
Drives: his girlfriend mad
Trader Rating: (14)
18_SSX is an unknown quantity at this point
do any of you guys have a whooshing sound when Spec stage III is installed? It makes that sound when accelereting just in front of the driver, not even under boost. My car is in the shop... they removed the clutch booster and the sound is gone... any help?
Sold: 1995 3000gt vr4 with dr800's and other pimp sh$t
18_SSX is offline   Reply With Quote
Old 12-01-2004, 03:39 PM   #57 (permalink)
Just havin' fun!
red3kgtvr4's Avatar
I've got a whooshing sound under my dash on the driver's side - but it's some kind of air/boost leak right behind the clutch. But I can't find the hose that's leaking. Didn't notice it before the clutch was installed... coincidence? maybe. I'm sure it's booster related, but I've heard pedal pressure is much stiffer with it removed.
Old 12-03-2004, 09:18 AM   #58 (permalink)
Gear Head
I'd recommend making an intake pressure tester as described on www.stealth316.com. If you guys have a boost leak it will make it very easy to find.
Old 12-03-2004, 10:29 AM   #59 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (20)
mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7mjannusch Level 7
I'd check the hose from the plenum to the clutch booster. Its on the driver's side of the plenum - large hose. There's a check valve in there, and you need to be able to blow air through the hose from the booster end towards the plenum end and not in the other direction.
Super easy to install it backwards and be putting boost pressure in the vacuum assist which will make you clutch harder to push in as well as make a hissing sound under boost under the dash.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'93 3000GT VR4 (Project for 2009)
'91 3000GT VR4 (Only a shell of its former self)
mjannusch is offline   Reply With Quote
Old 12-03-2004, 11:13 AM   #60 (permalink)
Just havin' fun!
red3kgtvr4's Avatar
Been there, done that. That's how I knew where the leak was. There's air rushing out of a hose or something right behind the clutch pedal inside the car. Seems to be coming out of the accordian-looking rubber boot. Any ideas how to get to the leak?
