#21 (permalink) | |
Member in good standing
#22 (permalink) | |
3SX FTL
1993 "dove gray metallic" Stealth R/T Turbo
Car is FOR SALE - 15k - PM me 6-speed transmission conversion, 2g front brake conversion, AWS delete with SK VR4 radius rod mod(BIG thanks to Joe G.'s website! )Kormex front LSD, Port matched Upper Intake -> Ported and port matched lower intake -> DR stage ]l[ heads, DR650Rs, ARC2 w/ 87mm MAF $ ARM1, Denso 255 hotwired, 720cc inj. fed by a Home made dual feed system for $800 w/ single hotwired intank pump, DR Weldin DSM sidemounts, DNP Y-pipe, 3SX poly motormounts, Vac hose reduction,, Chipped stock ECU -9000rpm rev limiter, Blitz DSBC in stock tape deck, VDO boost gauge, GREDDY EGT gauge, ATR downpipe - Borla catback w/ custom 3" flanges (3" all the way through), RPS flywheel, RPS clutch, Tein S-tech springs, Saner front and rear sway bars, Cusco adj. rear sway bar, 3SX adj. upper control arms, STEDEBANI front poly suspension bushings, 1995 VR4 front brake caliper conversion, Stillen Rotors,SCE extended wheel studs WELDED IN - THANKS SUPERCAR ENGINEERING! in NEW OEM hubs, Porterfield R4S pads, SILKOLENE brake fluid, Pro N1s w/ S03 Potenzas, 17x9 FNCRO1NFC01RN 5Zigens w/ NITTO 555Rs, POR15 on everything and a ton of new stock stuff... Car is FOR SALE - 15k - PM me |
#23 (permalink) |
TurboTension or others,
So what ever happened with your end links hitting? Did you figure out a solution. I just installed both front and rear Saner bars and have no issues so far with my ACPT driveshaft rubbing, but my axle nuts are hitting the linkage when I make a medium-hard turn. I tried taking the spacers out and replacing them with washers and that wasn't enough. I also put the bolts the other way with just the nut on the side of the axle and it still hits on one side. Next I plan to go to pick up some new low profile head grade 8 bolts to try. At last resort, I will try to use the stock end links with the Saner bar. Any other ideas? |
#24 (permalink) |
Steve mention a while back about a new design for the rear bar. Is this true? VR4swoosh, when and where did you buy yours?
Thanks
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8" For sale: 1. used stock oil sender & gauges 2. used A/C belt (10K on the belt) 3. Stock front and rear sway bars. 4. 3SX dual O2 simulator 5. Used 2'' couplers/reducers/hump hoses |
#25 (permalink) | |
Supporting Vendor
#27 (permalink) |
Warning: I'm an asshole
I'm curious as well.
1992 3000GT VR4
![]() ![]() --Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579 --First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon) --Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit. --Daily Driver: 98 Malibu, 4cyl, auto |
#28 (permalink) |
Here for the tuna.
I just bought / am in the process of buying a set of these. They were originally bought in June 2007 so I'm hoping they are the new design. I'll be autoXing with them on later this season, so I'll definitely post up about how they affect the balance / performance of the car through a tight course.
#29 (permalink) |
No more DSM...
Suscribed!
My DSM was a road race car, and I find out that the sway bars were the best bang for the buck in all the handling mods I made, I would like to have them on my TT, but I don't like all the issue the people have. I have PST one piece DS.
![]() Woah my DSM turbo gave birth to a pair of twins! |
#30 (permalink) |
I installed front and rear a year ago and here is what I had to modify
1. For the front I shortened 3SX end links by 1/8''. Pretty easy to do with basic tools. This way my front sway bar does not hit half shafts even when my suspension is unloaded. 2. For the rear I made 1/8'' shims to lift the bar a bit and to make sure that it does not hit the drive shaft. Otherwise, I did not have to modify anything on the car. After the install, handling improved a lot! Definitely worth it. Installing rear bar is fun, make sure you have a spotter and transmission jack, since you have to drop the whole rear sub-frame a bit. |
