Old 10-09-2005, 06:21 AM   #11 (permalink)
Supporting Vendor
SteveVR4 is an unknown quantity at this point
Default Re: Review: SANER awd sway bars from 3SX
I still need the diameter of these ACPT 1 pieces. I think the issue is the diameter of the DS not the bar. I also know that the rear bar is a slightly different shape than it was 2 years ago to allow extra clearance for the PST 1 piece driveshafts.
Someone please give me the diameters on the 1 piece 5 and 6 speed on the tube and where the flanges are welded on so I can do some checking.
As I stated before we had to give up developing a 1 piece aluminum because of diameter issues (they worked great on the lift but hit on the street )
I think this new model 1 piece driveshaft may have the same issue- I need to be able to check for sure.
Steve
www.3SX.com
SteveVR4 is offline   Reply With Quote
Old 10-09-2005, 08:24 AM   #12 (permalink)
3SX FTL
Turbo Tension's Avatar
Drives: the smokey behind u
Trader Rating: (8)
Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7
I was told by Justin at Dynamic that visually the bars are almost identical in diameter.
1993 "dove gray metallic" Stealth R/T Turbo
Car is FOR SALE - 15k - PM me
6-speed transmission conversion, 2g front brake conversion, AWS delete with SK VR4 radius rod mod(BIG thanks to Joe G.'s website! )Kormex front LSD, Port matched Upper Intake -> Ported and port matched lower intake -> DR stage ]l[ heads, DR650Rs, ARC2 w/ 87mm MAF $ ARM1, Denso 255 hotwired, 720cc inj. fed by a Home made dual feed system for $800 w/ single hotwired intank pump, DR Weldin DSM sidemounts, DNP Y-pipe, 3SX poly motormounts, Vac hose reduction,, Chipped stock ECU -9000rpm rev limiter, Blitz DSBC in stock tape deck, VDO boost gauge, GREDDY EGT gauge, ATR downpipe - Borla catback w/ custom 3" flanges (3" all the way through), RPS flywheel, RPS clutch, Tein S-tech springs, Saner front and rear sway bars, Cusco adj. rear sway bar, 3SX adj. upper control arms, STEDEBANI front poly suspension bushings, 1995 VR4 front brake caliper conversion, Stillen Rotors,SCE extended wheel studs WELDED IN - THANKS SUPERCAR ENGINEERING! in NEW OEM hubs, Porterfield R4S pads, SILKOLENE brake fluid, Pro N1s w/ S03 Potenzas, 17x9 FNCRO1NFC01RN 5Zigens w/ NITTO 555Rs, POR15 on everything and a ton of new stock stuff...
Turbo Tension is offline   Reply With Quote
Old 10-09-2005, 11:54 AM   #13 (permalink)
3SX FTL
Trader Rating: (8)
Here's what my saner bar did to my CFDS, it DEFINITELY has some development issues. Bear in mind with the car like this, the swaybar is not as low as it would be if the suspension was loaded, also the wear on the subframe is from the driveshaft whipping around after being broken.
This is before breaking, after 4 days of normal driving
after a big launch
I would like to thank my Borla exhaust for acting as a make-shift driveshaft loop.
Old 10-09-2005, 11:56 AM   #14 (permalink)
3SX FTL
Trader Rating: (8)
And here's my issue with the linkage. You can see slight wear marks .
Old 10-09-2005, 12:14 PM   #15 (permalink)
That Others May Live
F27Corsair's Avatar
Drives: 92 VR4
Trader Rating: (19)
F27Corsair is an unknown quantity at this point
Turbo- you need to register to view those pics. Got em uploaded anywhere else?
-Travis
-FIPK, Hard Y-Pipe, HKS SS-BOV, 15G's, DSBC
-Supra Pump, ARC2, S-AFC, ITC, 660cc's, Propane
-Ground Control, Strut Bars, Front Sway Bar
-DXD-F, Short Shifter, 2pc CFDS
-Stillen DP, ATR Cat-Back, No Cats
-Xdrilled Rotors, SS Brake Lines, Stillen Brakes
F27Corsair is offline   Reply With Quote
Old 10-09-2005, 12:22 PM   #16 (permalink)
3SX FTL
Trader Rating: (8)
going to photobucket now, thanks
Old 10-09-2005, 12:37 PM   #17 (permalink)
Supporting Vendor
Pics look like our prototype aluminum 1 piece shaft and what it did. Check that shaft diameter.
On the links, put them on the other side of the bar and they won't hit the bolts on the half shaft
Old 10-14-2005, 02:35 PM   #18 (permalink)
3SX FTL
Trader Rating: (8)
Thumbs down Re: Review: SANER awd sway bars from 3SX
Old 01-14-2006, 01:53 PM   #19 (permalink)
Member in good standing
Jim Floyd is an unknown quantity at this point
I have the Saners and one piece PST with no problems.
Jim Floyd is offline   Reply With Quote
Old 01-14-2006, 04:11 PM   #20 (permalink)
3SX FTL
Trader Rating: (8)
You try launching at 7000RPM on heated drag radials with stock shocks?
