Old 10-02-2005, 01:09 PM   #1 (permalink)
3SX FTL
Turbo Tension's Avatar
Drives: smokey/bandit
Trader Rating: (8)
Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7Turbo Tension Level 7
Default Review: SANER awd sway bars from 3SX
My first impression of these products was poor as when they were sitting on my doorstep, the swaybars had busted out of the box and the powdercoating was CHIPPING off. If you know much about powdercoat, when done correctly it is durable and would gouge before chipping. I alerted 3SX to this problem and they were very friendly about it.
After taking them to a local powdercoating business and having them re-done (gloss black, my favorite color - read cheap$) I set about isntalling them. The rear bar is very straight forward and install was relatively simple although the linkage left a little extra friendly slack to be desired, the fit was VERY tight. After re-installing my subframe I found that when the suspension is unloaded the linkage actually HITS the bolts holding the rear axles to the coupling hubs. This is garbage and should have been figured out in the R&D department at Saner before these bars were released. Other than that, everything on the rear bar was OK.
The front bar's installation left a little to be desired as well insofar as the old stock brackets were squared in the corners allowing the bolts to fit. The new brackets are poorly made and rounded therefore after spending 9128349 hours trying to get them aligned and all 4 supplied bolts started, they were pushed by the bolt's heads as the bolts were tightened. I consider this more piss poor engineering by saner as anyone mega concerned with precision suspension geometry would have a helluva time getting the bar 100% squared off. The front linkage is a little better than the rears, although the components seem to have been assembled from the bargain bin in the basement of a hardware store.
Final assment:
The handling of the car is recockulously improved now however, and on "sport" mode the suspension handles incredible. With new tie-rod ends and the poly bushings in my front control arms, the car stays flat and turns in incredibly. "Emergency lane change" maneuvers on the street resulted in at 45mph a ~13 foot max distance (EDIT: this was done on very sticky tires)(yes I tested, I am a geek) to be stable in the next lane over - basically for your nose to be in your lane, to your nose being completely in the lane over with the whole car behind it. The car stays FLAT going through curved on-off ramps or around corners, which will be much better on tirewear overall.
I REALLY like the improved performance, but will have to work something out with the rear bar before all my rear axle bolts are sheard off.
1993 "dove gray metallic" Stealth R/T Turbo
Car is FOR SALE - 13k - PM me
6-speed transmission conversion, 2g front brake conversion, AWS delete with SK VR4 radius rod mod(BIG thanks to Joe G.'s website! )Kormex front LSD, Port matched Upper Intake -> Ported and port matched lower intake -> DR stage ]l[ heads, DR650Rs, ARC2 w/ 87mm MAF $ ARM1, Denso 255 hotwired, 720cc inj. fed by a Home made dual feed system for $800 w/ single hotwired intank pump, DR Weldin DSM sidemounts, DNP Y-pipe, 3SX poly motormounts, Vac hose reduction,, Chipped stock ECU -9000rpm rev limiter, Blitz DSBC in stock tape deck, VDO boost gauge, GREDDY EGT gauge, ATR downpipe - Borla catback w/ custom 3" flanges (3" all the way through), RPS flywheel, RPS clutch, Tein S-tech springs, Saner front and rear sway bars, Cusco adj. rear sway bar, 3SX adj. upper control arms, STEDEBANI front poly suspension bushings, 1995 VR4 front brake caliper conversion, Stillen Rotors,SCE extended wheel studs WELDED IN - THANKS SUPERCAR ENGINEERING! in NEW OEM hubs, Porterfield R4S pads, SILKOLENE brake fluid, Pro N1s w/ S03 Potenzas, 17x9 FNCRO1NFC01RN 5Zigens w/ NITTO 555Rs, POR15 on everything and a ton of new stock stuff...
Turbo Tension is offline   Reply With Quote
Old 10-02-2005, 11:28 PM   #2 (permalink)
3SX FTL
Trader Rating: (8)
Default Re: Review: SANER awd sway bars from 3SX
After driving for a day and getting an alignment I found the rear sway bar is VERY close to my CFDS (ACPT one piece) under suspension load. Under cornering load it has actually rubbed on the driveshaft, however ACPT put a VERY durable coating on their product which has resulted in the powdercoat AND metal to be taken off the sway bar. If this wear progresses I will go in there with an angle grinder and to some precision grinding to prevent wear on my driveshaft. If I have to grind more than 1/4in into the bar, it will be removed as this is not acceptable, and the benefits of a CFDS far outweigh oversized, crap engineered swaybars.
Old 10-03-2005, 04:34 AM   #3 (permalink)
GOD
2Mitsus's Avatar
Drives: Like an asshole
Trader Rating: (42)
2Mitsus is an unknown quantity at this point
I'm curious if it would hit anywhere on one of the older ACPT shafts.
...DEAD...
2Mitsus is offline   Reply With Quote
Old 10-03-2005, 08:16 AM   #4 (permalink)
Supporting Vendor
SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4SteveVR4 Level 4
TurboTension- Please email me some pictures of what you are running into at Steve@3SXPerformance.com I have had mine on my car for 4 years and do not have the same issues and we have quite a few sets out there.
Also send me what the diameter is of the new ACPT 1 piece driveshaft (it may be too big of diameter (we ran into that issue with an aluminum 1 piece driveshaft we developed several years ago). I run the PST 1 piece on my own car.
Thanks,
Steve
Steve
www.3SX.com
SteveVR4 is offline   Reply With Quote
Old 10-04-2005, 06:45 PM   #5 (permalink)
3SX FTL
Trader Rating: (8)
Thanks,
Steve
no problemo, I am going to jack up the car tomorrow and I will take some pictures of what I am talking about. With the driveshaft the wear is easy to see but not to gauge as when the suspension is unloaded the swaybar is no where near the driveshaft.
Old 10-06-2005, 01:35 PM   #6 (permalink)
Moderator
HilbillyHomeboy's Avatar
Drives: Tin Indian
Trader Rating: (39)
HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7HilbillyHomeboy Level 7
IIRC, wraith had similar problems in the rear as well.
Jeremy
HilbillyHomeboy is offline   Reply With Quote
Old 10-07-2005, 03:44 PM   #7 (permalink)
3SX FTL
Trader Rating: (8)
Steve, did you get my email?
Old 10-07-2005, 05:30 PM   #8 (permalink)
Supporting Vendor
Got it. Waiting to lift my car up to see what I find.
Old 10-08-2005, 01:06 PM   #9 (permalink)
3SX FTL
Trader Rating: (8)
Well last night there was destruction under my car. This happened during a 7000rpm clutch dump.
reasons why the 3s awd vibrates with a 1 piece cfds?
in this thread reasons why the 3s awd vibrates with a 1 piece cfds?
Old 10-08-2005, 03:46 PM   #10 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
I had the same issues with my PST CFDS and Saner rear bar. I actually called 3sx to let them know about it and also ask them if they had noticed something like this on a customers cars and how they solved it. I think the guy I talked to on the phone thought I was a jerk and wasn't really that interested because I wasn't their customer. I only did it because maybe I could save them the grief from a future customer and maybe I could get some understanding if mine was installed wrong or it was indeed a mismatched parts problem.
Luckily, I realized the issue immediately because I heard the noises from the linkage hitting the axle bolts and investigated further. I removed the driveshaft and sent it out to get repaired and I put the stocker back on. I have not solved the issue, but the stocker also touches the Saner bar just slightly. Its all shiny in a band that goes around the stock DS right under where the sway bar sits. When my car had the PST in, I could only put two pieces of paper btwn the two with the weight on the rear, so I have not put it back yet. This happened to me in March 2003
Sam
wraith is offline   Reply With Quote
