#1 (permalink) |
This thread is to give a thumb's up approval for Carl, who sells a T304 dp for the Mitsu 3000VR4/Stealth TT combo.
Overall, I'm very happy with Carl's (Mitsuman's) downpipe product quality; T304 grade SS throughout, lots of undercarrage clearance, smooth mandrel bending, and a SS flex section to take care of engine movement. (2.5" primaries into a 3" pipe.) What's more, this is designed to hook up to the factory cat; important for those that have emissions testing. All in all, excellent value for the money. I've attached some pics for your reference. Notice how the banks flow together like a true collector, and there is lots of transfer case clearance, which eliminates excessive engine movement noise such as between power shifts. There is also a hanger support bracket for the DP that hooks up to the factory support location. He also threw in a correctly sized set of gaskets (the factory ones will restrict airflow, as they are more designed for 2.25" primaries, and a 2.75" collector) Good guy to work with. Hope he comes out with more products. If he does, I'll be first to test them, and let you guys know. Lates, Nobs Last edited by nobs : 07-11-2006 at 09:31 AM. |
#3 (permalink) |
You can either PM Carl directly using 3si addressing it to "MitsuMan",
or link into this: http://www.3si.org/forum/showthread.php?t=313328 I'm not sure what his prices are right now, but being in Canadian dollars you might save a few bucks on the exchange rate. Lates Nobs |
