Old 07-14-2008, 12:59 PM   #1 (permalink)
2xmks's Avatar
Drives: 1996 VR-4
Trader Rating: (7)
2xmks Level 32xmks Level 32xmks Level 32xmks Level 3
Default MechMan Alternators
I have searched several sources for high output alternators for our cars. After chasing several dead ends and companies who would not respond to repeated requests, I have finally found a company that will do it.
I spoke with MechMan and they currently build a custom alternator for our car. They do not use the factory housing. Instead they custom build a housing and bracket system that bolts right into the factory location. These housing are larger than the factory housing allowing for larger windings, rectifiers etc... I found a lot of their products on the RX-7 forum, with really high reviews.
The normal output for the alternator is 250amp with 155amps at idle. They are custom building me one that is 200amp with an under drive pulley. I will get better idle amperage without the chance of over winding the alternator when my car hits 8000rpm. The 250amp is fine for factory redline apps according to them. They offer coatings and various upgrades.
The alternator should ship tomorrow, (fully loaded). I will keep you all updated. So far their service has been A-1. They really seem to know there stuff and don't seem to mind taking the time to explain things to you. I am huge on customer service.
MechMan.com - High Output Alternators, AGM Batteries, 12- & 16-volt Charging Systems for Car Audio
93mm Ross Pistons,Pauter Rods,3SX Port and polished heads,Webcams race cams,ARP main/head studs,South Bend Stage 4"FE" clutch,720 cc injectors,Supra fuel pump,IPS FMIC, IPS TD05 headers/EVO III turbo kit,Tanabe exhaust, Hiro Axis 19x9.5 rear 8.5 front, Toyo Proxes T1R 285 rear 245 front
2xmks is offline   Reply With Quote
Old 08-01-2008, 10:30 PM   #2 (permalink)
2xmks's Avatar
Drives: 1996 VR-4
Trader Rating: (7)
Default Re: MechMan Alternators
I installed the alternator yesterday. This thing kicks ass! At a cold idle (I idle at 1000rpm's because of my cams) I have 14.5 volts. At a warm idle I have 13.8-14.1 volts. The best part is at idle with 2 fans that draw 25 amps each, 2 fans that draw 13 amp each, my head lights on, a/c on, stereo and amps on full the alternator voltage never dips. My factory alternator would dip all the way to 10.5 volts at this point, not this one.
They did a great job. I highly recommend them!
Old 08-02-2008, 07:18 AM   #3 (permalink)
***** User
Tricky222's Avatar
Drives: 91 VR4
Trader Rating: (63)
Tricky222 Level 5Tricky222 Level 5Tricky222 Level 5Tricky222 Level 5Tricky222 Level 5Tricky222 Level 5
Update us again in a month or two, if you will, to see how its holding up. That will be the true test.
Tricky222 is offline   Reply With Quote
Old 08-04-2008, 06:45 AM   #4 (permalink)
Stealth Like A Ninja
Darksurfr's Avatar
Drives: '91 Stealth TT
Trader Rating: (14)
Darksurfr is an unknown quantity at this point
cost? for future reference.
ECG '05- '08 / Attended NEG '05 - '08 / Attended
Darksurfr is offline   Reply With Quote
Old 08-13-2008, 09:33 AM   #5 (permalink)
jlgn_2000 is an unknown quantity at this point
Hey how is the alternator working out for you, I am very interested in buying one.
jlgn_2000 is offline   Reply With Quote
Old 08-13-2008, 09:43 AM   #6 (permalink)
modding addicted
Turbo Powered's Avatar
Drives: at high g's
Trader Rating: (23)
Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7Turbo Powered Level 7
Great info and pics, +rep.
Turbo Powered is offline   Reply With Quote
Old 08-13-2008, 11:10 AM   #7 (permalink)
2xmks's Avatar
Drives: 1996 VR-4
Trader Rating: (7)
So far I am very happy. Voltage is still right on target. Makes it so much easier to tune with consistent voltage . I have had no issues what so ever.
I believe I paid $449 shipped. If I remember correctly they said the price would be increasing shortly.
