Old 09-29-2008, 11:52 AM   #41 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
Default Re: Maximal Solid Motor Mounts
the transmission will make more noise for sure. You could not here my old car's at cruising speed, but acclerating around town you could hear it a bit. If your fluid isn't full of metal I wouldn't worry about it.
Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
cbehnken is offline   Reply With Quote
Old 09-29-2008, 08:59 PM   #42 (permalink)
q2418130103p's Avatar
Drives: 1993 Mits 3000gt VR4
q2418130103p Level 1q2418130103p Level 1
While I cant comment on your noise exaclty, I can definantly say that you will hear all sorts of new and scary noises with the solid mounts, as every engine vibration (and accesory vibration) will make its way into the cabin now.
Want to Buy:
  • Door Interior with no bubbles
q2418130103p is offline   Reply With Quote
Old 09-29-2008, 09:41 PM   #43 (permalink)
c_white's Avatar
Drives: 94 3000gt vr4
c_white is an unknown quantity at this point
thats what i was afraid of, but im kinda relieved now... when i get on it, the only way to explain the sound is a mustang supercharger kind of sound... its RPM dependent, not speed dependent, so i knew it was based the transmission, rather than a low-fluid level sound (transmission) i blew the diff. in my SL and it made a horrible noise as i came home from work one day, and when i heard this sound after installing the mounts, i was afraid to drive the car for a week lol
its kinda cool to hear the sound though, i hope to pull the precats to do the front/rear mounts soon... so i can gut them and net some more HP while im there lol
Thanks for the input, i feel better about the noise
c_white is offline   Reply With Quote
Old 09-30-2008, 02:02 PM   #44 (permalink)
Mean Green's Avatar
Mean Green is an unknown quantity at this point
I bought a set of solid mounts and installed them on the car. I absolutely love them, it to me, gives a more exotic feel to the car. If anyone has driven any exotic you will love these mounts for sure. The tranny noise is amplified significantly but I love the whine. I do not daily drive my car though but if I could I would.
Props to Maximal!
-Chris
1993 Panama Green VR4 - Cream interior - Black TE-37's with Nitto NT555's - XTD Stage 4 clutch - Kenwood headunit - KYB GR2's - 2 Infinity Baselinks - Infinity door and rear speakers - Dejon "Y" Pipe - Blitz BOV - Optima Red Top - Maximal Solid Mounts - Brass shift bushings - 14psi - restoring the car one mod at a time.
**Also parting out a 91 TT with 57,XXX original miles with blown motor. Pm me for details**
Mean Green is offline   Reply With Quote
