#31 (permalink) | |
Paid Member
I am planning on buying a set this week..but if there is an issue I may wait until everything is worked out.
#32 (permalink) |
I really dont consider it an issue at all. Its one of those things that you notice when you have a great product and you need to start nit picking.
If you are planning on buying a set DO IT, dont let that stop you, its a total NON issue.
![]() Want to Buy:
#33 (permalink) |
Supporting Vendor
Not sure if you're the one who e-mailed me on the water thing a couple weeks ago or not but that is the first i've heard of it the years I've been making them. Since then I started drilling a hole in them to allow them to drain out.
Terry |
#34 (permalink) | |
I just noticed it on saturday. Its really not an issue, but i imagine it will be beneficial in the long run. |
#35 (permalink) | |
Engineering Student
![]() NG06 - DOHC NA - ATX --- 16.6 --- 85 MPH NG07 - DOHC NA - MTX --- 15.7 --- 89 MPH 7.78 sec 0-60 3,044 lbs w/out driver1992 3000GT 1991 Stealth |
#36 (permalink) | ||||||||||||
#38 (permalink) |
Engineering Student
If you put a block of wood between the jack and the oil pan the wood will take all of the stress and you wont end up denting the oil pan. I've done it several times without a dented oil pan.
Just don't go putting metal on metal because you're bound for a oil starvation problem! |
#39 (permalink) |
kinda worried, i got a set from a fellow FL3S member, and i installed the driver and tranny to begin with, because i wasnt planning on removing precats/turbos to do front and rear mounts...
first thing i noticed was the immense vibration, which i love compared to blown-out stock mounts (on a VR4), which is exactly like you guys are talking about, a muscle car.... anyways, the stock bad mounts caused other problems... but my concern is under load i can hear transmission, from the cabin, it sounds like a supercharger when i punch it, but theres no noticable sound under deceleration, only under acceleration, has anybody had this issue? or is it something in the transmission/transfercase i should check? |
#40 (permalink) |
Boosted :D
I love mine. I don't even fell this vibration you're all talking about, it's still nicer than my truck haha
![]() 91 VR-4 K+N fipk intake, polished y-pipe, Turbo xs RFL bov, HKS exhaust with custom tips, southbend ofe clutch, custom pressure plate, joe p mbc, 300m output shaft: 25 spline, lightweight crank pulley, Palm data logger, Solid motor mounts, 120k tune up with oil pump. Future plans:15g's/19t's, larger fuel pump, larger injectors(680cc). |
| Thread Tools | |
