Old 08-15-2004, 07:14 PM   #1 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Drives: 1996 3000GT VR-4
Trader Rating: (42)
DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6DJAuggie level 6
Thumbs up LM1 WB02 Review
I finally got my car back from www.bostig.com (*GT/Multiades from 3SI) and the LM1 WB02 install was one of the things performed. I picked up the LM1 WB02 from www.eiptuning.com for $329.95 and the RPM wire for $99.
PROS
Price
Datalogging capability
Clear display
VERY good tech support with an online forum
Self-calibration
Real run-time capability
Can download 5 0-5V inputs (RPM + 4 others)
CONS
BIG (It fits in my center console)
$99 for the RPM converter wire to record RPMS
Only displays AF on unit
No digital display unit for visual
Currently, my LM1 is installed in the center console. A MOTOROLLA 2.5BAR MAP sensor is connected to a vacuum line as you would tap into for a boost gauge. A pressure transducer and a banjo bolt from AUTOMETER was used to tap into the fuel filter. All of this allows me to datalog RPM/AF/MAP (BOOST)/FP.
The WB02 is installed in the rear bank in the DOWNSTREAM 02 position. *THIS* resulted in a CEL. Both precats are gutted but I get a CEL (155/161 02 Heater) after removing the 02 sensor for the WB02 sensor.
I haven't had time to set up all of the conversions so that .9249294V actually means 13PSI (JUST AN EXAMPLE). I will take pics and give more information as I have it.
DJAuggie is offline   Reply With Quote
Old 08-16-2004, 11:47 AM   #2 (permalink)
Banned from Classifieds
smokinvr-4's Avatar
Drives: Smokinvr4@hotmail
Trader Rating: (100)
smokinvr-4 is an unknown quantity at this point
Default Re: LM1 WB02 Review
thats not a bad unit for the price, but not really designed to be a permanent mount in your car, pretty much a tune and go type thing.
smokinvr-4 is offline   Reply With Quote
Old 08-16-2004, 01:14 PM   #3 (permalink)
"The Fisherman"
pyun's Avatar
Drives: around scaring birds
Trader Rating: (75)
pyun is an unknown quantity at this point
'bout time someone made a review on this WB i have one myself (got it from eiptuning for $320 shipped - told them i was a vwvortex forum member ) i welded a new bung onto my stillen so i could still use all of the supplied o2 bungs (i'm a cali spec car)
i hope to have it running this weekend
and innovative's website DOES state that they're coming out with a digital display unit - much smaller than the actual unit itself
brian
pyun is offline   Reply With Quote
Old 08-16-2004, 01:15 PM   #4 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Trader Rating: (42)
I am getting a CEL in the stock rear bank position. Did you purchase the RPM convertor wire?
Old 08-16-2004, 01:19 PM   #5 (permalink)
"The Fisherman"
pyun's Avatar
Trader Rating: (75)
no i chose not to since i have Shiver's logger.. and i'll use the LM-1 in conjunction with that. if it comes to be some type of weird problem.. i'll end up purchasing the RPM wire
Old 08-31-2004, 03:43 PM   #6 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (20)
badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5
is the RPM wire something that can be made? Pics?
badass3000 is offline   Reply With Quote
Old 09-10-2004, 12:01 PM   #7 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
They sell an analog A/F meter that plugs into the unit and if its a standard A/F gauge, you may be able to pick up a Cyberdyne digital gauge and calibrate it to the LM1.
Sam
wraith is online now   Reply With Quote
Old 09-10-2004, 12:17 PM   #8 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Trader Rating: (42)
Is anyone using the RPM converter or any of the input connections on the RPM converter?
Old 09-13-2004, 02:34 PM   #9 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
I have the RPM converter, but not using it cause my 02 sensor died. Definitely do not drive very far without the box on for the 02 heater. They are not kidding when they say it will die quick without the heater driver working.
Sam
Old 09-13-2004, 02:55 PM   #10 (permalink)
Drives: 99 VR4
Trader Rating: (88)
SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7
sounds sweet.
Got my AEM and it's pretty nice. Still a bunch of peeves with it, but it works for now.
Get a o2 simulator. I should have mine today, and it gets rid of those CEL lights!
I think 25 bucks from www.o2simulator.com, but you can find them on ebay for possibly cheaper. I got a dual output for both my o2's.
BUT, you can probably get away with a resistor in the heater circuit (cheap fix) so that it doesn't think the heater circuit is bad. Since my car is OBDII I'm throwing a bad o2 code because of the precat elims.
SHiVeR-91VR4 is offline   Reply With Quote
