Old 04-10-2007, 11:47 AM   #1 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 1Struggly Level 1
Default The lethal_vr4 manual steering rack: Street test and review
The Lethal_vr4 manual steering rack is a converted stock hydraulically assisted rack. The rack is disassembled and all ports, fittings, and internal components specific to the hydraulic system are removed. Then the rack is greased and resealed, and new tie rods are fitted. The end product is exceptionally simple and clean. Installing the rack is more of a tedious process than a difficult one. The supports running from the front to rear crossmembers of the front subframe must be removed to swap the rack, as must the downpipe, transfer case, and front sway bar. At the time of my install, solid bushings were not available so the stock rubber pieces were reused. On 3/S with all-wheel steering (AWS), the signal lines to the valve for the rear rack will have to be disconnected.
I find the rack to be manageable during regular street driving and a worthwhile tradeoff for the benefits at the track. Effort at very slow speeds is high, which is to be expected, but it is not oppressive. I can fairly easily turn the wheel with two hands while the car is not moving at all, and though I wouldn’t want to parallel park regularly, it is not impossible. Palming the wheel or making significant one-handed changes to wheel angle at speeds below 5mph, however, is a thing of the past.
Above 10 mph effort to make normal turns in the road is acceptable. I certainly feel the weight of the rack, and the transition between the weightlessness of the center dead spot in our cars to the heaviness of an actual steering input is noticeable and dramatic. However, I was able to make these turns with one hand. However, I found that the effort required to make a tight turn—through an intersection, entering a parking lot, and anything else that requires greater than 50 or so degrees rotation of the wheel—was much higher than expected. This is absolutely a 2-handed process. Specifically, it is not the effort required to turn the wheel that I find to be higher than I expected, but the effort required to maintain that wheel angle. I think that this is partially due to my specific wheel/tire and suspension setup: I have Tein Flex with SCE’s camber caster plates. When I originally installed the plates a few years ago, the front wheels would return to center more forcefully (this is a product of increased caster). Further, I run 275s on 9.5” wide rims with a +36mm offset. The rims are fairly heavy. Even with power assist, steering effort was higher with these wheels and tires. I have not been able to reinstall my old camber plates or use alternate wheels/tires, so I cannot quantify the effects of my current setup.
At highway speeds the car almost feels as if it has assisted steering. The dead-spot transition I mentioned is there (no escaping that), but otherwise I can drive very easily on the highway with one hand—not that I do this normally. Lane changes are quick and easy.
In general, I think the benefits of this product outweigh the drawbacks, provided one is aware of them. Those of you who drive often in cities or who see your cars as comfortable weekend cruisers may not wish to purchase this. But if you are like me and take your somewhat daily-driven 3/S to track days, it looks to be a worthwhile modification. Not only does it drastically simplify the engine bay, the manual rack significantly increases feedback through the wheel. Bumps and imperfections are smoothly transmitted. My favorite part, I think, is that I can now feel how much the front is loaded up through the steering wheel. The hydraulic assist deadens most of this feedback; with the manual rack I can feel the steering effort decrease before I perceive the front unloading. I'm going to be very interested to see how this performs on the track.
Please feel free to contact me or Lethal_vr4 about any installation or driveability questions. For technical inquiries or questions about pricing or availability, please contact Lethal_vr4 only. It is his product and design; I am only a tester.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 260K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech XP8/AX6, 15x7 +30 Kazera KZ-M w/ Avon Tech Ra slicks, other crap here and there (like an air filter that doesn't have 1/4 of a million miles), arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 04-10-2007, 11:49 AM   #2 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Default Re: The lethal_vr4 manual steering rack: Street test and review
Power and manual racks side by side
Another view
The rack installed
Another view
Old 04-10-2007, 01:00 PM   #3 (permalink)
Indy here we come 06/2010
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2
Post moved to product reviews.
Better late then never? The 2009 3S Calendar
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress
Custom 12x18 poster/photo prints
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 04-10-2007, 01:05 PM   #4 (permalink)
Drives: 99 VR4
Trader Rating: (112)
SHiVeR-91VR4 Level 1SHiVeR-91VR4 Level 1
Weight savings?
SHiVeR-91VR4 is offline   Reply With Quote
Old 04-10-2007, 01:36 PM   #5 (permalink)
NG '03 6th Floor Crew
lethal_vr4's Avatar
Drives: 92 VR4/ 01 Lightning
Trader Rating: (60)
lethal_vr4 is an unknown quantity at this point
Thanks for the write up Clint. I appreciate an un-biased opinion.
Primary weight savings will be from the AWS delete and no PWR Steering pump. This is probably pretty high up on the weight saved per dollar. Right up there with a CF hood.
A small power gain from removing the parasitic loss from not having to drive the power steering pulley is another plus as well as increased simplicity.
Web log: http://apps.blackflagracing.com/Blog/
The Armada
'93 Sandstone Gray 3000GT VR-4
2006 3SI Ride of the Year
2007 All Mitsu Cookout, 1st Place 1st Gen 3/S
2008 All Mitsu Cookout, 1st Place 1st Gen 3/S
'92 Fiji Blue 3000GT VR-4
2004 All Mitsu Cookout, 1st Place 1st Gen 3/S
2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier.
BLACK FLAG RACING
'92 Emerald Green Pearl Stealth RT/TT
3.5L, 15Gs, AEM EMS
For Sale
lethal_vr4 is offline   Reply With Quote
Old 04-10-2007, 02:42 PM   #6 (permalink)
Drives: 99 VR4
Any idea how much the pump and assoc hardware etc weighs in at?
Old 04-10-2007, 02:53 PM   #7 (permalink)
lethal_vr4's Avatar
Trader Rating: (60)
I've heard the AWS itself is around 40 lbs saved... so *maybe* another 20 lbs for the pump/bracket and the remaining two PWS lines.
Old 04-10-2007, 03:13 PM   #8 (permalink)
Drives: 99 VR4
Pricing?
Thanks, this sounds great, I wish I had your car here to play with it and see if I like it.
Old 04-10-2007, 03:23 PM   #9 (permalink)
lethal_vr4's Avatar
Trader Rating: (60)
Pricing all depends on market. If few sell (less the five) expect prices to be ~$500.00 per unit, price will drop if more sell. I engineered this rack primarily as I wanted one and no other solution was available. Between the hottanking, sand-blasting, new finish on the rack, and new tie rod ends there is very little left for the actualy modification of the rack and shipping to customers (not to mention profit).
As of now Clint is the only other true manual rack in exsistance as I wanted a un-biased opinion when and if I were to possibly bring these to market.
I imagine that primary the serious drag racers and road racers will be interested in this modification. I expect total sales to be around 20 units over a few years.
I'll start a GB thread soon and post a link in this thread.
Old 04-10-2007, 04:49 PM   #10 (permalink)
Envious for a VR-4
NOMIEZVR-4's Avatar
NOMIEZVR-4 is an unknown quantity at this point
wow..Hey Clint are you ever going to sell your VR-4? I want to buy it..
Im serious too!! Great write-up..could we get a before/after picture of the engine bay?
Nomie
Ya the car this next time is going to have new parts, and not just junk I had laying around. So everybody better watch out, I went 9.73@151 with a pile of junk, imagine what it's going to do now.
The new toy.. 2005 ZX-10R
NOMIEZVR-4 is offline   Reply With Quote
