#1 (permalink) |
So I took the plunge and bought new coil packs, and the HKS Twin Spark to try to cure a misfire at high revs with my GTO TT. The difference is night and day - the car's far smoother at all revs, with no misfire at all. Probably took me 2 hrs to swap the coils and install the HKS - I didn't use the splice things in the box that came with the HKS though - they looked a bit cheap, so got some proper connectors and soldered them.
Of course, it may have been a weak coil, but I'm very happy now, and just waiting to go back to the dyno next week to see how far we can turn the boost up. So overall: HKS Twin Spark 9/10 (loses 1pt for the cheap splicers) Last edited by ScottP : 09-18-2007 at 11:56 AM. |
#2 (permalink) |
Hey man I need help I have a 3000gt vr-4 and bougt the HKS Twin Spark ignition system but i dont have a idea how to install the the hks the coils I see you conec your please help me .
#3 (permalink) | |
Obviously make sure the battery is disconnected while you're doing all this - once you're done, start the car up and make sure the little LED on the TwinSpark is glowing - it's not very bright at idle, but you should be able to see it. My car's in the garage again at the moment having the gearbox rebuilt, but I'll try to get some pictures up once I get it back! |
#4 (permalink) |
Did you got it from HKS?
intake,modified mass sensor,13G with TD04l housing, 450 injectors,iridium plugs,8,5 mill Magnacor wires,SAFC,hot wire 255lph Walbro fuel pump,stage III 6 pack clutch,gutted cats ,down pipe-full 3"exhaust. Main cat illuminated ,pillar gauges and more.....
#6 (permalink) |
hey man thank you for the information I got the unit connected to the car using the information you give me thank. I call HKS too see if they know how to wire the twin power HKS DLI to the car but they don't no how too. thank you .
Glenn |
