Autometer Wideband Review - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 07-03-2009, 10:48 PM   #1 (permalink)
Captain Obvious
Drives: 92 VR-4
DJ_Duck is an unknown quantity at this point
Feedback Score: 10 reviews
Default Autometer Wideband Review
I bought an Autometer Cobalt Wideband O2 gauge (#6178) from an eBay seller ihavethebestpriceperformance69 (The cheapest price I have seen anywhere).
The whole unit is pretty awesome. It uses the typical 6-wire Bosch wideband sensor, all the electronics (Sensor heater, calibrator, etc.) are contained inside the gauge housing, so all you have to pass up into the car is a tiny 10 wire harness. I was able to slide it up through the hole by the ECU without even having to remove the heatshield above the exhaust.
The gauge has a 0-4V analog output to use for datalogging, and it's fully adjustable. You can set what value to use for 0V and what value to use for 4V, and the output is linear between the two.
The gauge also has a momentary switch option (to use for WOT) to use the peak/hold feature. You can set it up to trigger off a WOT switch, and once you go off WOT you can display the peak AFR you hit during that run. It also has a warning function that is in effect only when the switch is triggered, you select the AFR to start the warning at, and if you hit that value or higher, all the LEDs on the unit start to flash.
The unit is also adjustable for fuel type, you can switch between AFR and lambda mode, and choose what AFR is shown for lambda values (ie 14.7 for gas, or 9.0 for ethanol).
Installation was ridiculously easy, one end of the harness snaps onto the Bosch sensor harness, the other end snaps into the gauge, then you connect the red wire to a +12V on ignition source, black wire to ground (optional: brown wire to WOT switch), and that's it. It took me longer to unbolt the plug in my downpipe then it did to install the gauge itself.
Total cost for the unit was $290 shipped, so it's more expensive then the Innovate or AEM, but still a good deal.
DJ_Duck is offline   Reply With Quote Quick reply to this message
Old 10-27-2009, 10:28 AM   #2 (permalink)
Banned
UTRacerX9's Avatar
Drives: like Jason Bourne
UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3
Feedback Score: 8 reviews
Default Re: Autometer Wideband Review
Any updates? How accurate would you say it is? Does it make tuning for power a lot easier? Thinking about picking one up myself.
UTRacerX9 is offline   Reply With Quote Quick reply to this message
Old 10-27-2009, 02:06 PM   #3 (permalink)
HLxDrummer's Avatar
Drives: 1993 VR4
HLxDrummer Level 1HLxDrummer Level 1
Feedback Score: 44 reviews
If you are logging the signal do you have to deal with the grounding offset/etc. or do you just run the signal wire?
To adjust the scaling do you need a computer?
Thanks for the review!
I like my LC-1 and it was only $170, but I had to cut a hole in my floor and deal with grounds/etc.
HLxDrummer is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 05:25 PM   #4 (permalink)
keithmac Level 1keithmac Level 1
Feedback Score: 4 reviews
Still like my Zeitronix ZT-2, 6 years old and still going strong and it comes with the software to datalog out of the box.
AOL`s stolen my picture!.
JDM GTO TT, Emanage Ultimate - EV14-1000cc
Twin Walbros, MAF-T Blow Through, M20, DLI
OS Giken R3C, TD04-16g's, Stainless PTFE lines.
keithmac is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
