Old 05-09-2008, 08:38 AM   #1 (permalink)
Boost Happy
Black_Sunshine's Avatar
Drives: a japanese dodge
Trader Rating: (70)
Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7
Thumbs down Autometer ultra-lite boost gauge
after owning the this mechanical gauge for 2+ years, the needle has started to vibrate in boost. i guess these things can't last forever and it was cheap, but it's still a waste of money since you either buy a better one later or have to send it off to get fixed. even if it gets fixed, it'll likely fail in another 2 years. i bought a pressure snubber ($20) which solved the vibrating problem, but made the response much slower. i've gone thru 2 autometer boost gauges now. 1 cobalt (electric) and the ultra-lite comp (mechanical) and they both failed. i'm never buying another autometer product. i upgraded to a defi blue racer boost gauge.
Black_Sunshine is offline   Reply With Quote
Old 05-09-2008, 10:18 AM   #2 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
Default Re: Autometer ultra-lite boost gauge
no problems with my autometer. I've had the car for 2 years and the gauge came with the car, so who knows how old it is.
It is one of the carbon fiber faced mechanical ones. Works great and is easy to read day and night.
Everyone on here trashes autometer, but in many other car platforms they are well respected.
Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
cbehnken is offline   Reply With Quote
Old 05-09-2008, 04:09 PM   #3 (permalink)
Cyberwwolf!!
BlackDream's Avatar
Drives: The Blackdream:RT/TT
BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7BlackDream Level 7
I've an autometer mechanical too from two years, it works good but I've to admit that the fact you've that long hose that go from the engine bay under your dash and then in your a-pillar (or like me that go out of the hood and then into the door) feel like if it is not very accurate but I think for 40$ that I payed that's honest
1992 Dodge Stealth RT/TT
Engine: K&N open intake, polished plenum, powdercoated valve cover, polished radiator cover, painted timing belt covers, red silicone hoses,cold air intake, chrome oil cap,Polished engine cover kit,...
Exhaust:Stainsless steel catback with no mufflers and stock tips look,test pipe.
Interior: Stainsless Stell door sills, autometer gauges.
Suspensions: Tein S.tech springs, -2° camber...
---> http://www.dodgestealth.it <---
BlackDream is online now   Reply With Quote
Old 05-09-2008, 05:41 PM   #4 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (26)
Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7
autometer is shit,,,plain and simple. Japanese electronic is the only way to go.
AEM EMS INVENTOR TRAINED JEDI MASTER CERTIFIED NINJA TUNER
www.gtpro.com
Dj4play is offline   Reply With Quote
Old 06-24-2008, 06:00 PM   #5 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7mywetdream Level 7
i have autometer 52mm boost gauge for over 3 years..and not one issue...still works like the day i bought it...
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
