#12 (permalink) |
ispro3000gt
vr4 owns. how can the pulley affect how quick the rpm's drop, i'm getting the flywheel and the underdrive lightened pulley... i dont' see it tho.?? elaborate plz? anyone else out there kno, i've heard it's a good combo... -matt
#14 (permalink) |
The 3sx crank pulley is like 5lbs lighter than stock. The obvious is it takes weight off the crank(just like a lightened flywheel), allowing the engine to rev faster. After I put the pully on, the car pulled harder especially around 3k. Definitly the best bang for your buck in any car. The only problem I had is my ac belt screams when I turn it on, but thats probably just loose.
As far as rpm's dropping i've heard of this, but don't notice it in my car. The basic concept is the heavier stock pully helps keep momentum of the engine turning when your off the gas. But if you think about it, when your using that power (racing), your shifting too quick to let the rpm's drop, right?
'94 SLIntrax | Addco | Flowmaster | Ek2 shorty | KN | Cianci Novara & Victory | '99 Lights | Powerslot |
#17 (permalink) | |
hoping
The 3sx pulley isnt underdriving. Its just lighter.
1991 pearl white STEALTH tt with 86,364 k&n fipk, 2nd gen vr4 wheels, snake eyes, proboost mbc, turbo xs type h 34 bov
05 quicksilver metallic GTO 6 speed (slow),lingenfelter intake, 06 tails (ricer) s.f. h pipe, gmm ripshift, dba 4000xs slotted and drilled rotors, porterfield r4-s pads, slp long tube headers with offroad pipes, heads? cam? fast 90? little squeeze? ls7 clutch (not currently doing its job very well)? few "extra" heavy pieces removed? 270/40/17 nitto drags? No dyno. Beats buick centuries from rolls so i'm assuming it could possibly go 14.5-17 @ 86-95 mph 1990 toyota 4runner, sr5, 197,000 miles, new (junkyard trans), broken master window switch, broken power steering pump, cracked windshield, rotted off exhaust, slightly crinkled front end, ripped intake hose, coolant leak from somewhere (headgasket?), misc stains everywhere from random stealth parts. FIRES UP EVERYTIME (except for when it is wet outside) havent figured that out yet. 1993 chevy lumina (track whore) 123,000 miles 2005 chevy corvette, m6 22000 miles, f55, 3lt, vararam intake |
#19 (permalink) | |
#20 (permalink) | |
