#21 (permalink) | |
Vr4 owns joo meant that his rpm drops quicker from the lightened fidanza flywheel he's got. Think of it this way, once you spin a nice heavy top, it spins forever, on the other hand,spin a lighter top and it will slow to a halt much sooner. That's why a lightened flywheel revs quicker and decelerates quicker when you lift the fuss vom gas, the stockers rev slower and hold the rpm longer. To each his own. |
#22 (permalink) |
Supreme creator of stuff
with no spanner wrench holes taking one off is a PITA but the quality and certainly support from them guys is second to none.
I will be running a few on a lathe by the end of the year...but for the money...get the 3sx one NOW bob |
#23 (permalink) |
N/A's are quick too
I have had mine on for 20,000 miles now no problems... its the perfect match to my lightweight flywheel. I think downpipe and crankpulley are the most bang for your buck items i beleive.
PICTURES...projects etc. etc.
1994 Caracas 3000GT n/a dohc 5-spd No Boost, No Bottle ... Just a base model ![]() *Stillen intake*DNP intake pipe*DNP Fed spec downpipe*3SX crank pulley*99' Lifters*ACT 2600 clutch*Fidanza flywheel*Catco Hi Flo Cat*3SX rear & trans poly mount*Ek2 Driver & front poly mounts*Silicone vacuum hoses*VR4 radiator*Custom "Firemans" Exhaust*Ek2 Plenum Spacer*Ek2 Fuel Loop*Magnecor Wires*NGK coppers*99' Arc spoiler*19" Polished Gewalt Evo's*Ground Control Coilovers w/helper springs*KYBs*3SX Adjustable Control Arms*Escort Passport 8500 X50*Alpine SEC-150R w/proximity*5" LCD TV*PS2*Hella HID conversion*PIAA H3*srs light on*musical window seal* 91 BMW M5 & 87 535im - 99 Lexus GS400 & 01 BMW X5 4.4 Ma's and Pa's . ![]() |
#25 (permalink) |
TROGDOR REBORN
I've also had mine on now for a good 15-20,000 miles with no engine problems. I did also come across the a'c belt squeeling while running. I came to the conclusion that (at least on mine), the tracks that the belt rides on were a little closer to the engine than on the stock pully therefore it stretched the belt to the side a little while running and would squeek. Not a big deal though, I played with my A/C tensioner pully a little bit and it's seemed to have gone away. I'd definately reccomend it though
Red 99' 3000GT VR2 "TROGDOR" coming in AUG '07
ENGINE 1.VR4 Engine swap..2.FWD 5 SPD SL Trans..3.Clipped and Ported TD04-15G Turbos..4.Synthetic Fluids..5.Mothers Polishes..6.Microtech Engine Managment..7.Optima Battery relocated to trunk..8.Aftermarket Clutch..9.Precision 550cc Injectors..10.Copper BCP7ES Plugs...11..Blue ACCEL 8mm Ignition Wires....12.Custom FMIC System with Piping...13.Turbo XS Type H-RFL BOV...14.TurboXS DSBC Dual Stage Boost Controller....14. Greddy Oil Catch Can Setup.... EXHAUST..1.Aftermarket Downpipe..2.Custom Exhaust.....INTERIOR..1.Meguires Polishes..2.Removed Backseats..3.Autometer Boost Gauge..4.Inovative Wideband o2 Setup...5.Autometer Dual Gauge A-piller holder...6.APC Black/Black Indy Style Race Seat with Red 5 Point Harness...EXTERIOR..1.Mothers Polishes..2.ADR 7 Spoke 17" Wheels..3.Fulda 245/45-17..4.Crossdrilled/Slotted Rotors...5.Red Dupont Painted Calipers...6.Mirror Tinting..7.10,000K HID LowBeam Headlights..8.Blue Plasma Reverse Lights...9. 3SX 99' Front Lip....10.Underbody Multicolor L.E.D. SystemSounds..1.Sony Headunit Ipod Ready with adapter cable..2.Pair 10" Rockford Phosgate "Punch" Subwoofers..3.Pioneer 760W Amplifier..4.Pioneer 6 1/2" Door Speakers...5.Rockford Phosgate 3 way 6X9 Rear Speakers...Suspension..1.3SX Front Sway Bar..2.3SX Front Polished Strut Tower Brace..3.3SX Rear Polished Strut Tower Brace..4.Eibach Springs(1" Drop) |
