Old 07-20-2008, 09:24 PM   #1 (permalink)
Mastrhu's Avatar
Drives: 1995 3000GT VR-4
Mastrhu Level 1Mastrhu Level 1
Default 3sx Active Aero Simulator
Got the product quickly but as far as the actual product goes...
It was nice to see my active aero work for the first time, even if it was for a day. Coming home from work that day the AERO light came on and the wing stopped working. Reset everything and the active aero would still would not work.
The active aero started working again on it's own the next day.....then quit working again the day after.
I pulled the box back out and checked the connections. BTW, I soldered the wires so it wasn't a loose wire or anything. Guess I got a faulty box. The instructions were meant for a car that still had the AA motor because the other connector's wire colors did not match the instructions....not that it was hard to figure out. I have a feeling it might start working on it's own again.
So overall the product sucks for being a tease. I'll contact 3SX and see what they can do for me.
Jason
1995 3000GT VR-4 A bunch of useless mods later gets me 502awhp @ 14psi. For Sale. http://www.3si.org/forum/f10/1995-30...lorida-433269/
1998 3000GT VR-4 15Gs w/ supporting mods...SOLD!!! RIP
Mastrhu is offline   Reply With Quote
Old 07-21-2008, 10:25 AM   #2 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (25)
Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7
Default Re: 3sx Active Aero Simulator
Ive used one and it did the same thing to me.
AEM EMS INVENTOR TRAINED JEDI MASTER CERTIFIED NINJA TUNER
www.gtpro.com
Dj4play is offline   Reply With Quote
Old 07-21-2008, 03:57 PM   #3 (permalink)
Supporting Vendor
SteveVR4 Level 1SteveVR4 Level 1
The simulator is a solid state piece- 99.99% of the time it will not come and go. It also requires that your rear aero and its ECU are working correctly in order to work. Sounds like you have another issue. I would check the controller and its connectors first.
Steve
www.3SX.com
SteveVR4 is offline   Reply With Quote
Old 07-21-2008, 04:28 PM   #4 (permalink)
Infinite
Freakshow's Avatar
Drives: 94VR4
Freakshow Level 1Freakshow Level 1
I got this as well just last month as installed it....nothing happened, although my aero light went out on the dash. I suspect the little switches are next to switch out at radio shack.
Freakshow is offline   Reply With Quote
Old 07-21-2008, 04:48 PM   #5 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (25)
so 0 for 3 on these ? I tired everything to get mine to work. Had to return it
Old 07-21-2008, 05:56 PM   #6 (permalink)
Supporting Vendor
When you installed the front motor back on did it work then? It won't solve other problems.
Old 07-22-2008, 05:26 PM   #7 (permalink)
Race the truck everyday
GRAVES's Avatar
Drives: 92 vr4
GRAVES is an unknown quantity at this point
Works a few times I have to remove the key and it will work a few more times . I cant say it worked with the motor in junk when I bought the car .
GRAVES is offline   Reply With Quote
Old 07-22-2008, 09:08 PM   #8 (permalink)
Mastrhu's Avatar
Mine started working today again. I'll see how long that goes. I would think if there was an issue with something else, it wouldn't work at all.
Old 07-23-2008, 10:31 AM   #9 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (25)
yes, I ended up pulling the tray and bar apart and leaving the motor plugged in and tucked it under the fusebox. Ive never gotten one to work.
Old 07-23-2008, 01:11 PM   #10 (permalink)
Supporting Vendor
For those who need wiring help on wire colors on other side of plug.
Here is some help of what color goes to what on a 93 VR4
Motor side Harness side
Blue Blue
Green/black Red
Black Green/Red
Red Black/Blue
Green/Red Black
