Old 04-24-2008, 11:28 AM   #11 (permalink)
Drives: 91 Stealth base
Trader Rating: (16)
91Stealth89 is an unknown quantity at this point
Default Re: Woot for SOHC Single Turbo
In for pics...,lots of them,lol good work
91Stealth89 is offline   Reply With Quote
Old 04-24-2008, 11:45 AM   #12 (permalink)
boosted
gipper72488's Avatar
Drives: 1990 gsx eclipse
gipper72488 is an unknown quantity at this point
yeah id like to see pics of the way these guys did their manifolds, and ive posted pics of the turbo im using in the av section, only got one response tho. ill post up more pics as i get farther into it
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
gipper72488 is offline   Reply With Quote
Old 04-24-2008, 11:54 AM   #13 (permalink)
kendo's Avatar
Drives: 97 sohc TURBO
kendo is an unknown quantity at this point
heres a shot of my manifold installed and wrapped
kendo is offline   Reply With Quote
Old 04-24-2008, 12:02 PM   #14 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
What injectors are you using?
If you are using 360's you will need something other than an SAFC to tune it. Stock SOHC inj are 180cc, jumping to 360cc if more than the correction an SAFC can handle.
The SOHC is 8:1, you should be able to run all kindsa boost!
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-811AWHP 747AWTQ Daily Driver 10.57@141mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Carolina 3S Forum
Import Power is online now   Reply With Quote
Old 04-24-2008, 12:24 PM   #15 (permalink)
I've been here way too long
Venom13132's Avatar
Drives: Small Block Chevys
Trader Rating: (109)
Venom13132 Level 1Venom13132 Level 1
subscribed for pictures
Venom13132 is offline   Reply With Quote
Old 04-24-2008, 12:33 PM   #16 (permalink)
boosted
i thought the sohcs ran a 8.9:1 compression?????
Old 04-24-2008, 01:22 PM   #17 (permalink)
that may be right, I was told 8 by someone, I had no idea since I never bother with them.
according to the Mitsu shop manual the SOHC 6G72 FWD is 10:1 and RWD is 8.9:1
So I am not sure
Old 04-24-2008, 01:25 PM   #18 (permalink)
boosted
So I am not sure
wow i could have sworn it was 8.9:1 for the sohc 3/s. god i hope so for the sake of boost lol.
Old 04-24-2008, 01:46 PM   #19 (permalink)
983KGTNA's Avatar
Drives: 98 3000GT
983KGTNA is an unknown quantity at this point
naw the sohc are 9.1cr and they have 270cc's i thought. maybe i am wrong. Thats what tony had told me. anyway parts should all be bought by the next few weeks and then the teardown will begin. pics will be up for sure.
National Gathering 2007 Stevensville, Michigan US131 Motorsports Park
Project Vrrooom Spooof Underway
983KGTNA is offline   Reply With Quote
Old 04-24-2008, 01:51 PM   #20 (permalink)
boosted
*big sigh of relief* good lol
