Old 06-19-2008, 09:51 AM   #1 (permalink)
SeekNStrike's Avatar
Drives: a4 quattro, sl-tt
Trader Rating: (20)
SeekNStrike is an unknown quantity at this point
Default Went down to 8:1 tt block how much boost?
Hello,
Im about to get my car back from the shop next week.
The shortblock has:
3sx forged rods
wisco forged pistons
oem forged crank
Stock IC + 9b's
I had my n.a motor in before, and ran 6-7 psi.
But now that I'm down to 10:1, How much boost can I run?
ATX to MTX cov, TT cov. TT longblock,forged 3sx rods,wiseco pistons,oem crank,supra pump,ground wire kit,blitz sbc,aem wideband,
fuel rail loop,spec stage 3, lsd s-afcII,turbo timer, autometer gauges. cracked trans
SeekNStrike is offline   Reply With Quote
Old 06-19-2008, 09:52 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Default Re: Went down to 8:1 tt block how much boost?
I don't see how it's any different than a VR-4 setup now. If you also have VR-4 injectors, you can run BPU boost which is anywhere up to 15lbs.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 06-19-2008, 10:08 AM   #3 (permalink)
boosted
gipper72488's Avatar
Drives: 1990 gsx eclipse
gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7gipper72488 Level 7
till you log knock lol. which should be 14-15psi safely.
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
gipper72488 is offline   Reply With Quote
