#1 (permalink) |
I have 97 3000gt 3.0l SOHC with A/T and wanna install a turbo on it. It has around 114k.. and I was wondering if I can do the used Eagle talon 14B turbo. However I am still looking for the options for the turbo and the installation procedures. I am also looking for the required modifications and upgrade for it... Any help will be appreciated.
#2 (permalink) |
Forum user
Repost your question in the NA to forced induction area and you should get some hits on your question.
VR4-"FOR OFF ROAD USE ONLY"
97 FWDTT Mods SOHC to 3.1L TT swap, ATX to 5-SPEED GETRAG, TE04H DR-19T's,Wiseco Forged Pistons, Custom FMIC, RPS MAX Street clutch,Tial BOV, Walbro 255,Custom Magnaflow 3'' exhaust,ATR DP,Custom FMIC,ATR DP,Catless, 3SX crank pulley, Emanage/E01, Derale fan controller, PTE 550 inj, AEM UEGO wideband, Re-located Optima Red Top,Krank Vents, EGR Blockoffs, MMCD logger, Stillen pads, drilled rotors, EibachPro springs, 3SX intake, intake hard pipes, IPO SX AFPR, 99 lifters,99 rear garnish, Racing Hart MP3 wheels,Snow Stg 2D Meth injection/Safe inj, http://www.hesspower.com/racecar.html |
#3 (permalink) |
SOHC you in the FACE
and the 14b turbo would be a horrible turbo for a 3.0 liter engine.
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit. 1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo ![]() |
#4 (permalink) |
SOHC Power!!!
Leave the car alone and sell it to me...then buy a TT.
'93 Green 3000GT Fidanza 2.1 cltuch / Fidanza flywheel / 3SX ss clutch line / 3SX crank pulley / Lethal_VR4 manual steering rack / TT radiator / BigTyla ground wires / ebay intake / '99 lifters / TT fuel pump / Maximal solid motor mounts / 3SX long headers / TT race pipe / TT cat-back / KSport coilovers / Maximal rear toe & camber arms / ![]() ![]() PM me about 3S service in the Kansas City area. ![]() |
#6 (permalink) |
boosted
yeah, the t3/t4 turbo would work better, and you will have to either make or have custom manifolds made
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
#7 (permalink) | |
if you want a 14b, you need two. anything smaller than a gt2871 and you absolutely need two. that is the smallest I would go for a single turbo on a sohc, but even then it would be stupid.
91 stealth r/t tt - part out: 91 stealth r/t tt - part out
91 stealth base - sold 91 stealth r/t - daily driver 93 vr4 - weekends 91 stealth r/t tt - part out |
#8 (permalink) | |
boosted
