Old 08-28-2008, 01:53 AM   #1 (permalink)
RL7
RL7 Level 4RL7 Level 4RL7 Level 4RL7 Level 4RL7 Level 4
Default TT Mivec build
Well I'm taking this kinda slow, but it should be fun. Putting a 6g72 mivec from a jap diamante 30m into a stealth and adding a couple turbos. Right now I'm trying to figure out what to do with the valve covers and oil pump (whether the curent location will interfere with the axle or if a 3s oil pump can fit). And to add to the chaos, it's going to be an auto (shift kit, end clutch, and trans cooler installed). Well, this is going to be something....
RL7 is offline   Reply With Quote
Old 08-28-2008, 03:40 AM   #2 (permalink)
We can make it better!
Drives: 1996 GTO
MichaelMR2 Level 1MichaelMR2 Level 1
Default Re: TT Mivec build
Brilliant to see someone finally getting into this, let us know how it goes...is that a hole in the sump?
Edit: if your going to all this effort...are you SURE you can't dig up a manual
MichaelMR2 is online now   Reply With Quote
Old 08-28-2008, 04:46 AM   #3 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7
i was hoping it was a 3.8l :P
How are you going to control the cam profile switchover?
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit.
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
Ondontii is offline   Reply With Quote
Old 08-28-2008, 05:30 AM   #4 (permalink)
Drives: 1996 GTO
I'm guessing a SAFC or the likes,@ondontii yeah I'm killing myself to get a 3.8L conversion going, mmm R35 killer (+ gear box strengthening + 19x10 rear + 19x9 front + negative camber + 16G's etc )
shame no-one seems bold enough yet ;D (but I am saving)
Old 08-28-2008, 05:49 AM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Nice swap!!!!!!! Keep us updated!
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 08-28-2008, 07:31 AM   #6 (permalink)
cyber bully
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
yeah, I will keep an eye on this thread.
Originally Posted by crazycracka928 View Post
^ lol "be the bigger man, poop on his hood"
Old 08-28-2008, 08:03 AM   #7 (permalink)
GOTRICE's Avatar
Drives: Mitsubishi Magna
GOTRICE Level 1GOTRICE Level 1
hmmm i swear the only mivec engines had the engine on your passenger side (our drivers) ie opposite orientation to our 2nd gen magnas (1st gen diamantes) and opposite to your 3000gt's.
The problem will be in the tuning. Throwing it out there early more hassle than its worth with the mivec + turbos.
Along this line of thinking i dont even know if the TT manifolds will bolt up.
Let us know your plans.
Ps im in Aus.
1995 Mitsubishi Magna 3L DOHC 24V
NA 3000GT Engine Conversion.
GOTRICE is offline   Reply With Quote
Old 08-28-2008, 12:03 PM   #8 (permalink)
RL7
MichaelMR2- I do have many manuals, including a very nice 6g7 series manual from 2001. The only problem is this engine is not referenced anywhere! I'm not even sure a service manual exists for this particular car. I've almost learned japanese trying to track one down. No holes in the engine that aren't supposed to be there... I think
Ondontii- I'm controlling the mivec with an rpm activated switch. It's controlled by 12v solenoids, give them power, profile changes. Suprisingly simple stuff.
GOTRICE- You're right engine is on the opposite side. That is where most of the the trouble spots are. NA manifolds bolt up fine (the manifolds and most of the other stuff bolted to the engine in the last pic is from the stealth), so the turbo manis shouldn't be a problem. Almost everything has bolted up without much trouble. Had to tap a couple holes and grind the motor mount bracket to clear that water pump, but nothing too serious yet. Can't know if it's more hassle than it's worth until you do it, so I'm doing it. I do anticipate tuning being a bitch, but you never know.
I think next I'm going to drop the pan and see if a 3s oil pump will bolt up. Worst case scenario, I'll have to use the stealth block with these heads. I'm trying to stay away from doing that, but it really may be the easiest option. At least once I pull the pan, I can see if it's a 2-bolt or 4-bolt.
Old 08-28-2008, 01:06 PM   #9 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (25)
Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7
Wow, I had been wondering when someone was going to attempt this. Keep us updated, this will be interesting for sure.
9b 13.2 w/ 93 Pump
Originally Posted by Jeremy Clarkson
I am sorry officer, my foot must have slipped off the clutch!
Monster Stealth is offline   Reply With Quote
Old 08-28-2008, 01:09 PM   #10 (permalink)
Paid Member
shooter83's Avatar
Drives: Z15A Stealth ES!
shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7shooter83 Level 7
i always wanted to see this happen! subscribed!
-Evan
My AWD Conversion
My Photo Gallery
^Live in Florida? Clicky Clicky ^
shooter83 is offline   Reply With Quote
