Thanks. I think I'll add it to my list and follow BigTylas writeup.
Here's my list so far. The only item I have on it's way is the 9b's.
9b turbos with oil lines and exhaust fittings
TT ECU
TT Wireharness adapter
FMIC
Exhaust manifolds and gaskets from VR4
o2 housings and precats - VR4
Oil housing - VR4
Joint on back of engine block for rear oil feed line
modify oil pan for oil lines
water housing - VR4
360cc injectors
fuel pump VR4
Injector resistor pack
Front motor mount bracket
Oil cooler with lines
S-AFC or S-AFR
Boost Gauge
Air/Fuel ratio gauge
Exhaust temp gauge (2 - frt & Rr)
Valve Seals (Clean up that little smoking)
Timing Belt and Water Pump (Due in 10k anyways)
If yous notice I am missing something and have any advice/suggestions please let me know. This will be my first TT build. I don't plan on rushing it and wasting $'s right away on new parts. I'd like to do this in the Spring, but if I have to wait, oh well.
So, if you have used parts sitting around and looking to sell CHEAP (or free
). Let me know.
Thanks,
Jason
