#21 (permalink) |
Z16-Abuser
From what you posted, Rolland. The front frames are not different. The blocks will swap car to car, but the engine side mount is different on 1, maybe 2 points. So you need the mounts from the donor block to go into the new chassis, but the chassis side mounts are the same. Just a note: tranny mounts are different between ALL transmissions, although I don't know if you were changing that. I do not have a mix-and-match engine (as in NA with TT parts on it) but I do have an ATX DOHC, a MTX SOHC with a conversion to TT in process, and 2 5spd TT's, under my belt. So I have seen some, not all the differences, and my information is for the most part, not just read, but I have seen some of the pictures, differences, explanations here and other places, so not all of it is on my own personal cars.
. Torque - The Underrated Anti-Depressant Drift racing - Proof that Japan finally got SMOKEY AND THE BANDIT on DVD.....and that the west coast has too many ricers |
#22 (permalink) | ||
***** User
But....Thank you for regurgitating information i posted in my first post, and i do agree that spreading misinformation is definitely NOT a good thing. But my info is correct(unless i've missed something browsing over what i posted, which is possible, but the info you've chosen to quote there isnt any). Soooooooooooo thanks for you input. This paragraph can also go along with you next post ![]() Back to the OP. I thought i answered your list pretty well, but apparently not well enough. So, post up a list of all the questions you want answered again, and me and mr. fury can answer them im sure.... |
#23 (permalink) | |
Panda Master
www.3sx.com
1992 VR4 - Sold - 12.5@110 1991 SL - Sold - 16.5@85 1993 RT/TT - Sold - 11.44@129.3 1992 VR4 - Sold 1994 VR4 - Sold 1993 SL - Retired - 10.19@140 1991 VR4 - Retired - 9.21@159 1993 VR4 - Sold 1992 Base Stealth ATX - DOHC TT |
#24 (permalink) |
Paid Member
My only input on this is that your best bet on budget and frustrations is to do the following.
Figure out which year of VR4 is going to best suit your needs: things like ECU, and wiring harness compatability.... Find a good cheap donor car keeping in mind the following. If your motor is healthy and is a DOHC, dont worry if the engine in it is running, unless you just HAVE to have the TT 8:1 motor. IMHO the NA 10:1 works just fine. All the little brackets, mounts, clips, wiring and stuff will be right there for you to pull from your donor. Not to mention being able to physically see where some of the stuff goes. After your all done you can sell off the parts you dont need, and greatly reduce the end cost of the conversion. That is not to say you wont need to purchase things like fuel control, help in the traction department "LSD", and other little stuff. A healthy NA 10:1 DOHC can be boosted, and reliable as long as you do things right and get a good tune on it. That being said, if my motor ever goes, I will be dropping the compression down to 8 or 8.5 :1 Good luck on your project. Hey MaTT.... I though I was being smart with my money...... who knew all TT Conversion drivers were cheap! ![]()
