Old 04-29-2008, 07:46 PM   #1 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (9)
ProwlerGT is an unknown quantity at this point
Question Swap in TT engine in place of NA engine
Ok I see these threads and other similar ones:
TT Conversion Bible
the TT conversion link thread
And all I see is talk of conversions. Are NA to TT engine swaps not talked about just because they're so easily done? or is it that they are too difficult or too much money to undertake?
Basically my questions are:
1. What are the main concerns dropping a TT engine into a NA frame?
2. Mounts fit just right? or need some weird metal work done? I know the frames are different, but dunno if the mount holes/bolts line up anyway.
3. Do you just swap the entire wiring harness all the way from the TT ECU to the entire engine bay?
4. Should the master cylinder and/or brake booster be upgraded? Calipers, rotors too?
5. Can you just buy a TT shortblock and put everything from the NA engine on top of it? Yes, I know I'm showing what I don't know. lol
6. What else?
I'm asking all this for a friend actually.
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 04-29-2008, 08:27 PM   #2 (permalink)
***** User
Tricky222's Avatar
Drives: 91 VR4
Trader Rating: (58)
Tricky222 Level 1Tricky222 Level 1
Default Re: Swap in TT engine in place of NA engine
TT Conversion Bible
6. What else?
DOHC blocks and heads are physically the same, so yes a tt engine will bolt right into the NA frame. All engine mounts are the same, the TT tranny mount is different as is the transmission(however FWD trannies will bolt up to TT engine blocks just fine and vice versa (as the blocks are the same)).
It would be a smart idea to swap harnesses just to make it easier as there are small differences, however you can make an NA harness work just fine on a TT engine, assuming OBD's are the same.
Brake cylinders, clutch cylinders, brake booster's are all fine to use when swapping in a tt engine. If you want more braking power then sure upgrade the brakes.
And yes you can just take a TT block and swap all the NA stuff onto it, assuming the are the same generation/OBD stuff.
TT engine swaps arent as common because people doing TT conversions are cheap and want to do it as cheap as possible. Spending an extra $500-$1500 for an engine when not absolutely necessary ussually doesnt fit into people's budgets.
Tricky222 is offline   Reply With Quote
Old 04-29-2008, 09:29 PM   #3 (permalink)
Z16-Abuser
VRFury's Avatar
VRFury is an unknown quantity at this point
Actually, heads are NOT the same. Neither are rotating assembly's. The block is (I believe) similar apart from oil squirters. The pistons are different, rods are different, the heads are different. There's more, but I haven't done one, so I don't know all the quirks and pitfalls. However, I think alot of people have done the swaps, just not too many write-ups. One I can think of off-hand is Richard-screen name Barefoot. He's gone from na dohc to awd 16g's and such. I will be doing one (or rather finishig one) soon, but haven't started on that project yet. BTW, if I'm correct, its Rolland, right? Applebees3/s FTW lol! Shoot me a pm and let me know how ya been. And then again, if I'm wrong, you'll read this post with a WTF look on your face
Torque - The Underrated Anti-Depressant
Drift racing - Proof that Japan finally got SMOKEY AND THE BANDIT on DVD.....and that the west coast has too many ricers
VRFury is offline   Reply With Quote
Old 04-30-2008, 05:00 AM   #4 (permalink)
custom user title
Stegmann Negative 1
@ Tricky222
You said all engine mounts are the same - but I thought the front engine mount has a lower profile for the TT motor due to the turbo on the front?
1994 3000GT SL: Lovely Daily Driver
1978 Plymouth Volare 225 Super Six Coupe: On light duty - previous DD for over 3 1/2 years. She deserves a break...for now mwuahahaha.
Stegmann is offline   Reply With Quote
Old 04-30-2008, 05:09 AM   #5 (permalink)
***** User
Tricky222's Avatar
Drives: 91 VR4
Trader Rating: (58)
The block and heads are physically the same, as in how the bolt up. As in NA heads will bolt up to a TT block and the other way around. Yes there are differences internally between the blocks and heads. Rods are the same, pistons are different due to different CR's between the two, and obviously the TT heads flow more than NA, none of which did i deny. However, in relation to his answer, yes the will physically bolt up with each other...
Originally Posted by Stegmann View Post
@ Tricky222
Well the bracket that mounts up to the engine is different yes, but the motor mount itself is the same. Sorry should've specified.
Old 04-30-2008, 05:35 AM   #6 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (9)
Talking Re: Swap in TT engine in place of NA engine
PM sent. LOL.
Old 04-30-2008, 05:44 AM   #7 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (9)
Question Re: Swap in TT engine in place of NA engine
So it is only the pistons and the flow passages in the heads that are responsible for the compression differences in the two engines - otherwise the engines are the same (aside from the engine mount bracket too)?
LOL - Sorry, but which of you is right? One says rods are different vs same etc... for other parts too? HUHH?
Rotating assemblies? Meaning pulleys or what else?
I don't know.... perhaps this is from inexperience, but it would seem to me swapping in an already ready to go TT engine would be a hell of a lot easier/cheaper than modifying and upgrading every single part on an NA engine to make it a TT converted. From what I've read the consensus pretty much is that you are better off just buying a stock VR4 and modding it vs converting to a TT from NA due to cost/labor.
Old 04-30-2008, 05:51 AM   #8 (permalink)
***** User
Tricky222's Avatar
Drives: 91 VR4
Trader Rating: (58)
It would be cheaper to just buy all the tt conversion stuff and use your current engine than buying a different engine and then all the tt stuff with it... Sure it'd be easier to just swap in a full TT engine, but its more expensive bc of the cost of the new engine.
Do a search for block differences or tt versus na block.
There are more differences than the ones i listed.
All NA's are 2 bolt, 93+ TT's are 4 bolt
TT's have oil squirters
91-92 have cast cranks, 93+ have forged, regardless of tt or na
Rods are the same
TT has 8:1 pistons, NA 10:1 (which account for CR differences)
TT heads flow better than NA ones
TT cams are different than NA
Valves and associated hardware are the same
Front mount bracket is different on a TT
Water housing on TT has coolant ports for the turbos, however both bolt up the same.
Old 04-30-2008, 07:53 AM   #9 (permalink)
Venom Speed Shop
Venom13132's Avatar
Drives: 00Passat,95 FD,93R/T
Trader Rating: (97)
Venom13132 Level 2Venom13132 Level 2Venom13132 Level 2
no conserns at all
All the mounts work the same. Transmissions bolt right up. The only thing is for the FWD transmission you have to shave the nub off the crank shaft for the flywheel to fit.
yes. its basically like doing the TT conversion after you get the TT long or short block in there, i suggest long block.
not necessary on any of those. Its always fun to replace your hub assemblys, calipers, and rotors with TT 4 piston big breaks thought.
pretty much everything bolts up the same. These engines are basically identical besides the TT parts
6. What else?
send me a pm or instant message if you have any questions about something you are about to buy and i will steer you in the right direction. I have put a tt engine in an NA before and I am actually doing it right now on my blue stealth.
Venom13132 is offline   Reply With Quote
Old 04-30-2008, 03:16 PM   #10 (permalink)
Boost Junkie
Trader Rating: (13)
rush6432 is an unknown quantity at this point
rods are all the same........... blocks are the same minus oil squirters. cranks seem to be the same as well from what i recall. heads are physically the same as far as bolting them on.
-92 Stealth RT TT - 42K original miles and stock.
-03 Hyundai Elantra GLS-T (Yes its turbo..) - Daily
-92 Eclipse GST - Parted out
-96 Talon TSi AWD (Auto) - Sold
-95 Talon TSi AWD (5spd) - Sold
-94 Mirage (4G63T Swapped) - Parted Out
-89 Dodge colt (4g63 swapped w/ t67) - Sold
- 92 Stealth R/T TT - sold
- 94 3000GT Single Turbo - Sold
rush6432 is offline   Reply With Quote
