Old 05-10-2008, 07:49 AM   #21 (permalink)
Z16-Abuser
VRFury's Avatar
VRFury is an unknown quantity at this point
Default Re: Swap in TT engine in place of NA engine
From what you posted, Rolland. The front frames are not different. The blocks will swap car to car, but the engine side mount is different on 1, maybe 2 points. So you need the mounts from the donor block to go into the new chassis, but the chassis side mounts are the same. Just a note: tranny mounts are different between ALL transmissions, although I don't know if you were changing that. I do not have a mix-and-match engine (as in NA with TT parts on it) but I do have an ATX DOHC, a MTX SOHC with a conversion to TT in process, and 2 5spd TT's, under my belt. So I have seen some, not all the differences, and my information is for the most part, not just read, but I have seen some of the pictures, differences, explanations here and other places, so not all of it is on my own personal cars.
Torque - The Underrated Anti-Depressant
Drift racing - Proof that Japan finally got SMOKEY AND THE BANDIT on DVD.....and that the west coast has too many ricers
VRFury is offline   Reply With Quote
Old 05-10-2008, 08:59 AM   #22 (permalink)
***** User
Tricky222's Avatar
Drives: 91 VR4
Trader Rating: (63)
Tricky222 Level 1Tricky222 Level 1
Originally Posted by ProwlerGT View Post
Ok 3 things.
1. Which of you responding have actually done this swap, witnessed it being done or even assisted in the swap process?
2. Which of you are going off of knowledge from others or readings?
3. I'm sure someone swapping to a TT engine would not care if NA parts work on the TT engine if it means a performance "DROP" and that said people responding (I thought would) should assume that I or my friend wouldn't want to put NA heads on a TT block if they do not FLOW as good as the TT heads do. So please if there's a performance drop or "strength issue" using NA parts on the TT engine setup I or my friend would not want to use those parts or know about it. When I ask what NA stuff can be used on the TT engine I'm asking about stuff that can move over without concern and with the intent that it will perform the same exact task the same way. If not then its of no use.
The main thing I was hoping to accomplish with this thread was really a "swap list" in LIST form, but I'm not even sure which of you guys is right vs wrong and while I'm inclined to believe some of you more than others there is still a lot of overlapping information here.
I have personally never done this and I'm not even doing it to my car. My main concern up front was that the frames on the TT vs NA are in fact different and I didn't think the TT block would mount up at all. The rest of the stuff ..... please let us know if you done this or if you are just reporting info you've read up on.
Do some searching and you can come up with your own info, my info is correct and im not sure what vrfury is even arguing about it me. He seems to just be covering himself with the things i have corrected for him. Yes i have done many of these swaps and just about anything else, so yea my information is correct. This info is coming from personal experiences and information read and told to me. But like i said, if you dont beleive me or want to know for sure, just do some searching on it and you'll find the exact same info i posted, but said by other people.
Originally Posted by VRFury View Post
Yeah, fuck your mother, james. I did not argue that they do not have the ability to bolt up, I'm saying there is no point to it.
I have rebuilt both engines, and it doesn't take a rocket scientist to see they are VIRTUALLY the same. However, there seems to be almost no sense in doing this cost-wise. Yes, THE DOHC'S BOLT UP TO THE DOHC, N/A OR NOT. But if your doing one setup, there are certain parts that are necessary, you can't just bolt some of this and some of that and make it work. Just saying, "yeah that will work", is like saying you can bolt a caravan motor into this car. Sure it will bolt up, but try closing the hood over that huge intake.
So check your ego at the door. Trying to help so there isn't half-info being given to a good guy. Enough of us have gotten fucked by half-info, we don't need it in our own forum.
Hmm, swearing huh? The sure sign of a desperate man. My chemistry teacher once said that people swear/cuss because they cant think of anything better to say, which i think still holds true in this case.
But....Thank you for regurgitating information i posted in my first post, and i do agree that spreading misinformation is definitely NOT a good thing. But my info is correct(unless i've missed something browsing over what i posted, which is possible, but the info you've chosen to quote there isnt any). Soooooooooooo thanks for you input. This paragraph can also go along with you next post
Back to the OP. I thought i answered your list pretty well, but apparently not well enough. So, post up a list of all the questions you want answered again, and me and mr. fury can answer them im sure....
Tricky222 is offline   Reply With Quote
Old 05-10-2008, 09:21 AM   #23 (permalink)
Panda Master
maTT's Avatar
Drives: with one foot.
Trader Rating: (19)
maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7
Ok 3 things.
I've done more than I can count. I do them Monday-Friday 8:30-6pm. I agree with you that this thread is confusing. Feel free to call the shop and I can tell you everything you need to know.
I no longer work for 3SX however I still strongly recommend them for your 3S parts and service needs!
maTT is online now   Reply With Quote
Old 05-10-2008, 09:48 AM   #24 (permalink)
Paid Member
Jomojr's Avatar
Drives: 1993 TT ATX w/TT ECU
Jomojr Level 1Jomojr Level 1
My only input on this is that your best bet on budget and frustrations is to do the following.
Figure out which year of VR4 is going to best suit your needs: things like ECU, and wiring harness compatability....
Find a good cheap donor car keeping in mind the following. If your motor is healthy and is a DOHC, dont worry if the engine in it is running, unless you just HAVE to have the TT 8:1 motor. IMHO the NA 10:1 works just fine.
All the little brackets, mounts, clips, wiring and stuff will be right there for you to pull from your donor. Not to mention being able to physically see where some of the stuff goes.
After your all done you can sell off the parts you dont need, and greatly reduce the end cost of the conversion. That is not to say you wont need to purchase things like fuel control, help in the traction department "LSD", and other little stuff.
A healthy NA 10:1 DOHC can be boosted, and reliable as long as you do things right and get a good tune on it. That being said, if my motor ever goes, I will be dropping the compression down to 8 or 8.5 :1
Good luck on your project.
Hey MaTT.... I though I was being smart with my money...... who knew all TT Conversion drivers were cheap!
1993 GT TTATX
Pimpin the TT-ECU and NA-TCU Baby!
Link to Pics Vids and Info
3SX FANBOY
Jomojr is offline   Reply With Quote
Old 05-22-2008, 01:12 PM   #25 (permalink)
Look Slow... Go Fast
fotoman's Avatar
Drives: 1992 3000GT
fotoman is an unknown quantity at this point
Hey guys I have a 91 N/a and plan to put a new engine in it. If I buy a crate TT engine and drop it in my car will it run? I'll buy turbos later to finish the set up but will the engine run with my ecu and electronics?
Thanks.
fotoman is offline   Reply With Quote
Old 05-22-2008, 02:02 PM   #26 (permalink)
cyber bully
Trader Rating: (14)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
Thanks.
all and all yes. there might be one or two things that you need to do but there is not much difference in the motors other than compression and oil pump. If you do put the TT 8:1 motor in your car with out turbos then it will be slower than it is now because the motor will be 8:1 instead of 10:1.
Old 06-03-2008, 05:24 PM   #27 (permalink)
Z16-Abuser
VRFury's Avatar
Originally Posted by Tricky222 View Post
Do some searching and ...
Either way you want to view this, you came at me as an ass in the first place. That would be the only reason I would comment in that fashion towards you. And I'm sure you'll spend enough time trying to think of the most appealing way to turn what I say into some sort of 'your-dumber, more rednecker, I have a science degree, my friend owns the fastest stealth fwd tt, Alan had dinner at my house last nite so I'm that cool... fuck I don't know, just to impress yourself or other people on the internet. I would hope maybe your not intent on being an internet king and maybe you just have some difficulty communicating without being rude, alot of people on here do.
Pretty much, we've clogged the thread more than I would have liked to, and I apologize to Rolland and other 3sers. Maybe we somehow straightened out questions somewhere in this anyway.
Old 06-03-2008, 07:03 PM   #28 (permalink)
***** User
Tricky222's Avatar
Drives: 91 VR4
Trader Rating: (63)
Nope. But thanks for bringing this thread back from the dead just to say that. Gotta get that ego stroked.
Old 06-14-2008, 01:55 PM   #29 (permalink)
rcoulter's Avatar
rcoulter is an unknown quantity at this point
ok an awd conversion was mentioned a few times.
i have a 94 n/a 3000gt and i would like to drop in a vr4 engine
how would i go about converting it to awd?
rcoulter is offline   Reply With Quote
