Old 08-11-2008, 04:07 PM   #61 (permalink)
Ahhh. La Fee Verte.
Beau_Jester's Avatar
Drives: 94 3kGT base
Trader Rating: (9)
Beau_Jester Level 1Beau_Jester Level 1
Default Re: Supercharger
SC vs Turbo ?
I seem to loose my get up and go when I shift into 3rd gear. The shift from second to third with a 6000 rpm shift point dropped my rpm below 4000. It is like forever to get momentum going and then oh oh here comes the turbo car passing me. My trap speed was only 95mph, though.
Red 94 Base 3000GT:
TK Eaton supercharger @ 8psi, 360cc injectors, SAFC II, 3SX downpipe, Magnaflow w/2.5" pipes, Dyno tuned @ 223 WHP, Quaife LSD, double synchro 3/4 gears, 10% over 5th gear.
93 Black RT/TT Stealth:
Newest project. Engine to be rebuilt, 15g turbos, RC 550cc, MAFT Gen-II, GM 3.5" MAF, Dejon blow-thru intake.
Beau_Jester is offline   Reply With Quote
Old 08-11-2008, 04:30 PM   #62 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (78)
Why would you shift at 6000RPM with a 7000 redline and 7300 rev limit?
Old 08-11-2008, 04:33 PM   #63 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
Originally Posted by Beau_Jester View Post
SC vs Turbo ?
Do you have any intercooling or I guess aftercooler for a supercharger?
Not to mention the parasitic loss of the supercharger to begin with.
Anyways even with 9b's I notice a decent pick up in the 90-100+ area once I upgraded to DSM SMIC's? The stock IC's would get heat soaked pretty good with just one good pull through 3 gears pretty much killing the topend ability.
DSM SMIC's are about twice the size and don't get hot and the pull stays pretty much the same. Just a thought as to the difference in pull up top.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 08-12-2008, 11:38 AM   #64 (permalink)
Ahhh. La Fee Verte.
Trader Rating: (9)
I shift at 6000 rpm because the dyno indicated I had no gain in power after that point. This was the shift point the tuner selected.
No intercooler....yet. I have some stock VR4 side mounts that I may install but I am not sure how much they will help since I will be cooling the charge before the air reaches the supercharger. The water/alcohol injection will probably be more effective.
Old 08-12-2008, 02:34 PM   #65 (permalink)
Drives: 93 RT/tt
two things
1 just because you are not gaining any more power beyond 6k rpms doesn't make that your shift point. The goal is to have the most AVERAGE hp for your run down the track or whatever meaning you want to take your shift point a little PAST peak hp so that when you shift and the rpms fall they do not fall to far down the powerband to DECREASE your average hp for the run. Don't be surprised if your car runs a little bit better taking it to 6500 through 2nd gear and 63xx for 3rd.
2nd you are right about the alchy injection but with a supercharger if you have it set to come in you will be using alot of alcohol since you will build boost so easy.
Old 08-12-2008, 03:59 PM   #66 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (78)
Kibwe nailed it. Just because you dont gain power doesnt mean you shift there. You want to shift whereas your RPMS fall right back into the powerband. Shifting at 6000 rpm you are severely hurting your times.
