Old 03-23-2009, 06:50 AM   #1 (permalink)
91 3000GT SL
Cyote's Avatar
Drives: 91 3000GT SL
Trader Rating: (14)
Cyote is an unknown quantity at this point
Default SuperCharged Indepth help
What i've been working on for a while now with my 3k. say about 2 or 3 weeks in but im almost done....if anyone knows a good shop to tune my car and what they charge LMK
Still need to Complete
1.Wait for injector resistors to come in DONE
2.Wire in the resistors DONE
3.Wait for SAFC2 to come in DONE
4.Install SAFC2 DONE
5.Wait for Wideband setup to come in DONE
6.Install Wideband setup DONE
7.Re-relocate the brake reservoir DONE
8.Extend some wires to reach DONE
9.Make custom tentioner pulley DONE
10.Make custom throttle mount DONE
11.Put car back together and see if i need to do anything else
12.Powder coat some more DONE
13.Tune
Money Spent so Far (considering i got everything i was suppose to get in the first place)
All Prices are what i paid shipped for them
$182 for SAFC2 Black Special Edition
$40 for Dual Gauge Pod Pillar Attachments
$196 for AEM UEGO Wideband Setup
$15 for Injector Resistors
$60 for Supercharger With Recent Rebuild
$30 for Brake Booster Reservoir Relocation Kit
$30 for V-Belt to Ribed Belt Conversion (PS pump,PS Tentioner,Crank Pulley)
$35 for TT Injectors
$20 for Custom Gatorback Belt
$20 for Boost Gauge
$50 for Walbro 255 Fuel Pump
$50 for materials to build box
$50 for cutting blades and grinding stones and other stuff i needed to do metal work
$40 for powder for powder coating and for spray paint
$5 for pulley
$40 for gaskets and Purple Power and paint stripper
$10 for some mexican chile spoon things
$50 for supply of rockstar energy drinks
$50 for supply of pepsi
$50 for anything else i may need
Free bloody knuckles
Free cuts and dirty clothes
TOTAL OF $1023 <--- OMFG i didnt spend that much money
1.Supercharger(Rebuilt) + a 2.5" pulley boys pulleys!!!!!! $60 shipped thanks to phattlard
2.SAFCI $85 shipped
3.Brake reservoir off a 1st gen eclipse to relocate mines + hose - $30
4. V belt to rib belt conversion kit (1st gen to 2nd gen) - Ran like $30
in shipping
1. tt injectors - $35 shipped
Need to get
1. fuel pump
2. injector resistors
3. boost gauge
4. boost gauge holder
5. custom belt
6. gaskets + o rings
O yeah and MONEY LOL
Cars
1991 3000GT SL - injen intake, Maximal Performance Test Pipe, EK2 Down Pipe, Lanz Home Made Solid Motor Mounts, ACT 2600 extreme street clutch, 7" touch screen stereo, 2x10" kicker competitions, ohio STS, MSD 8.5 plug wires, Iridium plugs, Solid shifter bushings, Supercharger running 5 PSI, walbro 255, VR4 injectors.
1991 3000GT VR4 - STS, 2x12", ssqv BOV
1988 3rd gen Honda Prelude - ebay intake.
Cyote is offline   Reply With Quote
Old 03-23-2009, 08:34 AM   #2 (permalink)
My car whines!!
casperlynn's Avatar
casperlynn is an unknown quantity at this point
Default Re: SuperCharged Indepth help
FIRSTLY AND MOST IMPORTANT!! Make sure your engine and trans are healthy!!
1.Eaton M90 Supercharger (completely rebuilt!)- $450 minimum. A third gen M90 from PSE superchargers is $600.
2.TT injectors (will not work!) You need high impedance injectors for a NA- $400 minimum
3.TT Fuel Pump ( use a Walbro or Supra FP and a hotwire kit to maintain voltage) - $250 minimum
4.Customized Plenum (must be aluminum, starting with salvaged upper plenum runners) - $500-$1000 (no salvaged plenum as a base and fabing a completely custom intake plenum--$2000 plus)
5. Customized adapter plate for TB attachment to SC intake- $50-$100
6. Fuel pressure regulator- $125
7. Custom (steel plate) belt tensioner bracket and pulley- $175-200
8. Blower pulley- $100
9. Blower oil- $16
10. SC/ power steering belt- $25
11. A/F gauge (wide band)- $100-300
12. EGT gauge- $50-300
13. Boost gauge- $50-300
14. Piggy-back ECU controller- $200- $2000
15- Water injection (to prevent pre-detonation) $300-$1200
16. Intake gasket- $20
17. In-line fuel pressure gauge- $25+
18. 6 rib crank pulley (for the AC/ALT and supercharger) - $50+
19. Covert 4 rib power steering pump pulley to a 6 rib- $100+
This does not include misc. connectors, vacuum hoses, etc.
....I went from a plagued V6 to a reliable straight 6, it's all about the beamer now!
casperlynn is offline   Reply With Quote
Old 03-23-2009, 04:40 PM   #3 (permalink)
91 3000GT SL
Cyote's Avatar
Trader Rating: (14)
well phatlard layed me out his setup
3rd gen M90
Custom SC pulley, or Crank pulley.
walboro 255l
VR4 fuel injectors + resistors
SAFC II
Boost gauge
Custom intake manifold and brackets,
Custom belt and pulley setup.
Thats pretty much basic enough for me for now any ways then i will work on
all the stuff casperlynn said so use aluminum then???thickness to use???anything else besides alum.??
Old 03-23-2009, 05:26 PM   #4 (permalink)
My car whines!!
casperlynn's Avatar
Originally Posted by Cyote View Post
so use aluminum then???...yes thickness to use???...3/8" or 1/2" plate..anything else besides alum.??....No
Old 03-23-2009, 05:47 PM   #5 (permalink)
91 3000GT SL
Cyote's Avatar
Trader Rating: (14)
OK got yeah
Old 03-23-2009, 06:01 PM   #6 (permalink)
91 3000GT SL
Cyote's Avatar
Trader Rating: (14)
3rd gen M90,M62,M45 $100 to $500 depending on witch 3rd gen eaton I get
(would a twin screwed SC be better for this build ??)
Custom SC pulley, or Crank pulley. - Free
walboro 255l - $40
VR4 fuel injectors + resistors or other What cc’s am I looking for ??- $80
SAFC II $150 + depending on a lot of factors
Boost gauge $20 + also depending on different factors
Custom intake manifold and brackets, $50 to $100
Custom belt and pulley setup(looking to put a tensioned pulley on this setup) $30 to $100
Total if get the lowest price = $470 + (just until I can get the other stuff)
o and some tunning i probably will need also !!
Old 03-23-2009, 09:22 PM   #7 (permalink)
boosted
gipper72488's Avatar
Drives: 1990 gsx eclipse
gipper72488 is an unknown quantity at this point
you could look at gettin dsm 450ccs. i think you still need the resistor packs, but itd leave room to upgrade your boost later
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
gipper72488 is offline   Reply With Quote
Old 03-23-2009, 10:07 PM   #8 (permalink)
91 3000GT SL
Cyote's Avatar
Trader Rating: (14)
Yes i do want to leave room for boost later so i dont run out of + hp because then you will get use to it after awhile then want more
but i want a basic setup then build on that setup >> Very basic <<
so TT injectors wont work with the resistors??Just looking to get minor boost from stock pully size
Old 03-23-2009, 10:11 PM   #9 (permalink)
91 3000GT SL
Cyote's Avatar
Trader Rating: (14)
is there a certian type of tensioner pulley i would need if i did put one on??? Or can it be any tensioner pulley???? it will have to be custom but is there any specific specs it has to be??
Old 03-25-2009, 07:16 AM   #10 (permalink)
91 3000GT SL
Cyote's Avatar
Trader Rating: (14)
bump on ???
