#12 (permalink) |
Boiler Up
You do realize that 14b's are TD05... That means you would have to either have TD05 manifolds or get adapter plates... Stock VR4 turbos are TD04's. There is a big difference there. I would say stick with a 13G for a FWDTT. Too much turbo and you won't be using very much of your first couple of gears...
1997 3000GT SOHC [3SX Downpipe] [3SX Testpipe] [3SX Lightweight Pulley] [4" Air Intake] [Custom 2.5" Catback] [MSD 8.5mm Plugwires] [18" DR Rims] ![]() |
#13 (permalink) |
ugh, i just realized that 14b is a td05 like you said ealyer today, stupid me. yeah prolly go with 13g. i told him he's going to need to put 10-12" wide front tires on it for traction in first and second gear.
#14 (permalink) |
!!Too Much Nitrous!!
with out a retarded offset you arnt going to be able to fit anything wider than about 9-9.5 on the front wheels.
a LSD would be a better investment anyway. and a Clutch that can take abuse as you feather it out of the hole.
#17 (permalink) |
'92 RT
PArts for Sale 2008 still available- http://www.3si.org/forum/showthread.php?t=369574 |
#18 (permalink) |
Forum user
![]() Built and Tuned By RUSH6432,IPS motorsports and myself. Currently 384whp@wategate 6.8psi Weight=2890lbs Tials are in Dyno pull on the way pushing for 10-13 on pump and 15-18 on meth or race fuel....hell maybe even run both and go for 19-22 ![]() |
| Thread Tools | |
