Old 04-19-2008, 03:18 PM   #1 (permalink)
'92 SOHC Stealth
SOHCStealth's Avatar
Drives: '92 SOHC Stealth
SOHCStealth is an unknown quantity at this point
Default Spark Plugs for SOHC turbo conversion.
Hello everyone. I am rounding the final bend of my SOHC turbo conversion and need help and advice with one last thing. I am currently running NGK Iridium plugs in the car but have read that a turbo car requires different plugs with a different gap. What would you guys reccommend as far as a brand of plug and gap for a turbo application?
'92 Dodge Stealth SOHC - 3SX Adjustable Camber & Toe Arms, Eiback Springs, KYB Struts, 3SX Steel Braided Brake Lines, Stillen Brake Pads on Stillen Cross-Drilled Rotors, 3SX Steel Braided Clutch Line, 3SX Lightweight Aluminum Crank Pulley w/ Gatorback Belts, 65mm Big-Bore Throttle Body w/ Half-Shaft Mod, ARP Head Stud Kit, 3SX Poly Motor Mounts, 3SX Short-Throw Shifter w/ Solid Shifter Bushings, 3SX 2.5" Downpipe, RT High-Flow Cat, Custom Stainless 2.5" Cat-Back w/ Flowmaster 40, 18" ADR SZ1 Wheels, Etc...
SOHC Single Turbo Project in progress.
SOHCStealth is offline   Reply With Quote
Old 04-20-2008, 06:50 PM   #2 (permalink)
'92 SOHC Stealth
Default Re: Spark Plugs for SOHC turbo conversion.
Bump...
Old 04-20-2008, 07:19 PM   #3 (permalink)
doing the impossible
lDoomZdaYl's Avatar
Drives: Her Crazy
lDoomZdaYl Level 1lDoomZdaYl Level 1
Denso Iridium
lDoomZdaYl is offline   Reply With Quote
Old 04-20-2008, 07:31 PM   #4 (permalink)
gipper72488's Avatar
Drives: dodge stealth
gipper72488 Level 1gipper72488 Level 1
the densos would be a little hotter i believe. that would help make sure that you have plenty of spark so that you dont detonate.
I <3 booost
93 sohc-sold
90 gsx-purchased 6/5/08
3 inch turbo back exhaust
valve job, ported head
MBC set at 14psi
gipper72488 is offline   Reply With Quote
Old 04-20-2008, 07:38 PM   #5 (permalink)
'92 SOHC Stealth
So i should go with a hotter plug then? The recommended plug for the SOHC is already a 5 heat range, would this be sufficient? or would a 4 be better?
Old 04-20-2008, 09:24 PM   #6 (permalink)
SOHC Power!!!
SOHC3000GT's Avatar
Drives: Like a nut job......
Trader Rating: (91)
SOHC3000GT Level 4SOHC3000GT Level 4SOHC3000GT Level 4SOHC3000GT Level 4SOHC3000GT Level 4
Why not just run the same plugs as a TT? Makes sense to me...
'93 Green 3000GT - Back on the road!!!
Fidanza 2.1 cltuch / Fidanza flywheel / 3SX ss clutch line / 3SX crank pulley / Lethal_VR4 manual steering rack / TT radiator / BigTyla ground wires / ebay intake / '99 lifters / TT fuel pump / Maximal solid motor mounts / 3SX long headers / TT race pipe / TT cat-back / KSport coilovers / Maximal rear toe & camber arms /
SOHC3000GT is offline   Reply With Quote
Old 04-21-2008, 06:47 AM   #7 (permalink)
i was told that you should run the hottest plug that you can with 93 octane to make sure you have good spark and ignition that way it helps you aviod predetonation. using the factory tt plugs makes sense to me
Old 04-21-2008, 12:07 PM   #8 (permalink)
Shockeere's Avatar
Drives: people insane
Shockeere is an unknown quantity at this point
to put an end to the garbage in this thread.
go to napa, ask for NGK coppers for a 91 3000gt dohc turbo awd. if you are going to be making over 400 hp, ask for them in one heat range colder. get a spark plug gapper tool for 3 bucks while you are at it, and gap them to .035 .
i promise you will be burning through ANY plugs you buy while you are still tuning your car. run the coppers till everything is stabilized, then get some denso iridiums and be happy.
what kind of turbos are you using?
edit, start with a 6 heat range and go 7 if you are making over 400 hp at the crank.
91 stealth r/t tt - part out: 91 stealth r/t tt - part out
91 stealth base - sold
91 stealth r/t - daily driver
93 vr4 - weekends
Shockeere is offline   Reply With Quote
Old 04-21-2008, 03:30 PM   #9 (permalink)
'92 SOHC Stealth
Thanks for the help.
I cannot use DOHC plugs beceause the SOHC plugs are a different thread pitch and I believe they are a different style all together. I am using a single 20g with a 10cm monster turbine housing. I was going to use coppers to tune with and after I get things stabilized switch to an iridium/ platinum plug. I was just confused as to what heat range would be a good starting point.
Thanx again for the reply.
