Old 10-19-2009, 01:20 AM   #1 (permalink)
'92 SOHC Stealth Turbo
SOHCStealth's Avatar
Drives: '92 SOHC Stealth
SOHCStealth is an unknown quantity at this point
Default SOHC Single Turbo Conversion Completed.
Hey all! It has been some time since I logged in last. I have been busy with work and putting countless hours in at completing my conversion.
As some of you may remember, I am utilizing a TD05H 20G Turbo. Some feel that this turbo is small for the engine but I have realized VERY good gains thus far. I have Max boost set to 12PSI. On a fairly good tune my factory clutch lets go at about 8-9PSI around 3700 RPM.
If I had to guess I would say the engine is making 300-350HP without knock before the clutch begins to slip.
Stay tuned, Pics to follow in the coming days and as always any questions members may have are welcome.
'92 Dodge Stealth SOHC - 3SX Adjustable Camber & Toe Arms, Eiback Springs, KYB Struts, 3SX Steel Braided Brake Lines, Stillen Brake Pads on Stillen Cross-Drilled Rotors, 3SX Steel Braided Clutch Line, 3SX Lightweight Aluminum Crank Pulley w/ Gatorback Belts, 65mm Big-Bore Throttle Body w/ Half-Shaft Mod, ARP Head Studs, 3SX Poly Motor Mounts, 3SX Short-Throw Shifter w/ Solid Shifter Bushings, Single TD05H 20G, FMIC, FMOC, Hotwired Walbro 255, 525cc Precision Injectors, 3SX underhood fuel kit w/ Custom SOHC Fuel Loop, Custom Ceramic Coated Headers and Turbo Downpipe, RT High-Flow Cat, Custom Stainless 2.5" Cat-Back w/ Flowmaster 40, Various GM Sensors, Innovate LC-1 Wideband, Tuned with MAPECU 2.
SOHCStealth is offline   Reply With Quote
Old 10-19-2009, 07:03 AM   #2 (permalink)
Oil In My Veins
autopsycho's Avatar
Drives: 1996 GTO SR
autopsycho is an unknown quantity at this point
Default Re: SOHC Single Turbo Conversion Completed.
Good job, awaiting some pics and vids, would be fun to see.
autopsycho is offline   Reply With Quote
Old 10-19-2009, 08:25 AM   #3 (permalink)
Quit while you're ahea
Trader Rating: (34)
green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2
Quit teasing! Pics or ban!
The American dream is not a birthright - Me
Supercharger kit for sale
Old 10-19-2009, 08:31 AM   #4 (permalink)
noob-saibot
my3kgtvr4's Avatar
Drives: the women crazy
Trader Rating: (8)
my3kgtvr4 is an unknown quantity at this point
Time for a T88 and 125 shot
my3kgtvr4 is offline   Reply With Quote
Old 10-19-2009, 09:39 AM   #5 (permalink)
1994 stealth sohc 5spd
93stealthsohc's Avatar
Drives: 1994 dodge stealth
Trader Rating: (-1)
93stealthsohc is an unknown quantity at this point
good work man, in for pics
1994 dodge stealth sohc 5
Junked 93 stealth es atx...
http://www.cardomain.com/ride/3117711
93stealthsohc is offline   Reply With Quote
Old 10-19-2009, 11:17 AM   #6 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Very cool, in for pix
-Chris
91VR4-3.0L-Stock heads and Cams-811AWHP 747AWTQ Daily Driver 10.57@141mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 and NG10 Title Sponsor
3SX Performance
3SX Performance Service Email
Carolina 3S Forum
Import Power is online now   Reply With Quote
Old 10-19-2009, 01:08 PM   #7 (permalink)
TT's suck
TheOmniscientRT's Avatar
Drives: 94 Stealth Base
Trader Rating: (13)
TheOmniscientRT Level 2TheOmniscientRT Level 2TheOmniscientRT Level 2TheOmniscientRT Level 2TheOmniscientRT Level 2TheOmniscientRT Level 2
wanting to see more
TheOmniscientRT is offline   Reply With Quote
Old 10-19-2009, 01:19 PM   #8 (permalink)
TPW: The Prophet
AlmosN8kd's Avatar
Drives: without wearing much
Trader Rating: (44)
AlmosN8kd is an unknown quantity at this point
Pics or it didn't happen.
AlmosN8kd is offline   Reply With Quote
Old 10-19-2009, 01:21 PM   #9 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (144)
Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3
I'm sure I can imagine the setup so I'm not too intereseted in pics. I'm more interested in actual numbers instead of guesses.
Old 10-19-2009, 02:46 PM   #10 (permalink)
CarthageGT is an unknown quantity at this point
Pics! Awesome job on the conversion. I'm gonna try to get my single turbo done next year. I have a few questions. Are you still using the light weight crank pulley? You think it will cause any problems especially if your at 350hp?
CarthageGT is offline   Reply With Quote
