#3 (permalink) |
depends on what stage kit he gets. if he gets the base turbo setup and then ebays piping and figures up the set up on his own, then it could come out cheaper. i know there is another thread in this forum that one guy is trying it. it would e nice if they produced a kit for the 3/s, that would give us sohc guys a good oportunity
I <3 booost
93 sohc-sold ![]() 90 gsx-purchased 6/5/08 ![]() 3 inch turbo back exhaust valve job, ported head MBC set at 14psi |
#4 (permalink) |
I am going to try it homemade style instead of from STS. Have the turbo already, waiting on buddy to make flange to bolt up to exhaust then gotta get oil figured out but our stock sending unit to the oil filter has a Y piece for turbo oil lines due to turbo option with our cars so that should get oil to the turbo. Coming back is different but the spot im looking at is fairly close to the oil pan so vaccum should be enough to pull the oil back. Then the only other thing to do is find out where i can run the intake pipe back up to connect with the MAF without jepredizing ground clearance and its ready to run. Perhaps someone with more underbody time could help with clearance issues because i havent spent much time down there. Everyone worries about fuel but my thought was that MAF would correct itself and just hold injectors open longer or just a change to a bigger injector but im no expert so let me know what you think.
#5 (permalink) | |
I personally would figure something else out for the oil to a return from the turbo. The way you have it planned can starve your turbo for oil, causing your turbine to seize, or burn up. Turbos need alot of oil to keep cool. I also think you arre under estimating the a/f ratios that differ from n/a engines and fi You will need things like an ecu/any ecu that will work im not sure theres options. And bigger injecters are a must, a higher flow fuel pump, things like this. |
#6 (permalink) | |
***** User
There wont be enough 'suction' to properly drain the oil, your going to need a scavenge pump. You still need an ecu, injectors, intercooler piping, etc... |
#7 (permalink) |
doing the same here as far as no kit, i have vr4 injectors which i think are 450 cc, and will change fuel pump to walbro 255, i think it will take a pump for the oil , i do know that intercooler is not necessary, being as exhaust to the turbo is so much cooler than comming from manifold and compressing it into the return tubing to the plennum also cools it much more. not sure about the mas yet need to do more research.
#8 (permalink) | |
SOHC you in the FACE
When people have the ability to weld, I dont see why they dont just do a normal turbo setup in the engine bay.
Brent
1992 Duster -13.0@104 - 8psi boost and slipping clutch -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit.1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo ![]() |
#9 (permalink) |
Play that Funky Music
do stock twin setup.
You will thank yourself later.
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold 91VR4 Black-5027s-3.0L-Stock heads and Cams- 614AWHP 557AWTQ uncorrected 24psi Daily Driver 3SX Performance 3SX Performance Service Email |
#10 (permalink) |
I love her▼
Dapps, you are gonna spend a buttload just trying to get your car set up for any type of F.I, let alone going single turbo. Don't fool yourself. Whoever said stock VR4 injectors are 450cc, that is incorrect, they are only 360cc and you will need resistors to run them properly.
