Old 07-12-2009, 05:30 PM   #1 (permalink)
F@ckin snow!
bones66's Avatar
Drives: 1991 dodge stealth
bones66 Negative 1
Default Single turbo or tt conversion?
I am playing with the idea of boosting my na stealth and i am pondering between a single turbo conversion or a tt. my question is would the tt setup actually be counter productive because of pushing so much power through two wheels? it seems to me and i might be completely wrong about this, but a tt setup on a front wheel drive is over kill cause all youll do is roast the front tires. i was wondering if the front wheel drive would be better controlled with a single turbo? so could the tt setup actually benefit you more than the single turbo in a front wheel drive. thank you.
bones66 is offline   Reply With Quote
Old 07-12-2009, 06:43 PM   #2 (permalink)
91 3000GT SL
Cyote's Avatar
Drives: 91 3000GT SL
Trader Rating: (19)
Cyote is an unknown quantity at this point
Default Re: Single turbo or tt conversion?
i say and probably along with every one else. a tt conversion would be the cheapest way and takes little to no fab. work to do cuz everything is bolt on. but i mean either way if you boost your car with FWD then your gonna have traction problems
Cars
1991 3000GT SL - injen intake, Maximal Performance Test Pipe, EK2 Down Pipe, Lanz Home Made Solid Motor Mounts, ACT 2600 extreme street clutch, 7" touch screen stereo, 2x10" kicker competitions, ohio STS, MSD 8.5 plug wires, Iridium plugs, Solid shifter bushings, Supercharger running 5 PSI, walbro 255, VR4 injectors.
1991 3000GT VR4 - STS, 2x12", ssqv BOV, custom solid motor mounts, gutted cats, vac. reduction, erg plates
1988 3rd gen Honda Prelude - ebay intake.
Cyote is offline   Reply With Quote
Old 07-12-2009, 08:55 PM   #3 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Twin turbo.
No reason to make things more complicated.
h
-Chris
91VR4-3.0L-Stock heads and Cams-811AWHP 747AWTQ Daily Driver 10.57@141mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 and NG10 Title Sponsor
3SX Performance
3SX Performance Service Email
Carolina 3S Forum
Import Power is online now   Reply With Quote
Old 07-12-2009, 09:06 PM   #4 (permalink)
Single Turbo Flamer's Avatar
Drives: 1995 3000GT VR4
Trader Rating: (12)
Single Turbo Flamer Level 1Single Turbo Flamer Level 1
Originally Posted by Import Power View Post
Twin turbo.
h
-Chris
x2
Video is at a pathetic 9lbs of boost (wastegate) hahaha
Video of My Car Here
Single Turbo Flamer is offline   Reply With Quote
Old 07-12-2009, 11:05 PM   #5 (permalink)
VR4-GASM's Avatar
Drives: Evo IX SE
Trader Rating: (11)
VR4-GASM is an unknown quantity at this point
Twins.
1995 3000GT FWD Twin Turbo
16psi, 450s, E85
13.52 @ 110.56 with a 2.17 60'...13psi.
332FWHP-342TQ...16psi with many boost leaks.
SOLD 8-09 :-(
2005 Crystal Gray Metallic STi
*far from stock* Totalled by a 16yr old girl 10-26-09
Current: 2006 Cool Silver Metallic Evo IX SE - not stock
VR4-GASM is offline   Reply With Quote
Old 07-12-2009, 11:25 PM   #6 (permalink)
Drives: 1994, Pearl White
Memphetic is an unknown quantity at this point
I have the parts to make this happen for you! Let's do this dance!
Memphetic is offline   Reply With Quote
Old 07-13-2009, 09:20 AM   #7 (permalink)
wait, is it DOHC or SOHC?
-Chris
Old 07-13-2009, 10:44 AM   #8 (permalink)
F@ckin snow!
bones66's Avatar
bones66 Negative 1
it is dodge stealth es dohc. so honestly what are my solutions for traction other than the obvious lsd. i would suck to have an awesome boosted car that you cant drive in traffic or hold on the road
Old 07-13-2009, 10:49 AM   #9 (permalink)
F@ckin snow!
bones66's Avatar
bones66 Negative 1
sounds like fun my issue is finances, as always i would love to do a conversion when my second job starts again and i actually have money.
Old 07-13-2009, 03:32 PM   #10 (permalink)
I'm unloading what I have for pretty damn cheap...
