Old 07-05-2009, 12:25 PM   #11 (permalink)
jedimastermopar is an unknown quantity at this point
Default Re: Single Turbo project
The '87 Grand National put out 276hp, so I figured using the stock or slightly better than stock fuel components would net similar numbers, since we are starting out with a better breathing base engine than the 87 3.8 gm engine. I know people can queze extra boost off of these turbos and get into the high teens and low 20's to get the 1000+hp, but its allot of work getting the boost up like that, heads, cams, exacting exhuast tuning sutff like that. If I can squeze out 10 - 15 psi I would be more than happy with the results.
jedimastermopar is offline   Reply With Quote
Old 07-05-2009, 12:47 PM   #12 (permalink)
1st NG08 / 2nd NG07 Drags
Drives: 93 VR-4
neverenoughhp is an unknown quantity at this point
1000+ hp from the stock turbo, you may want to look into that some more.
be prepared to put in some work to get a custom single kit done. using stock 9bs would be easier and on a 10:1 (wait what car do you have?) and fwd they feel pretty quick. of course if i ever owned a na and wanted more power i would just sell it and get a tt. they are so cheap now and you dont have to waste time working on it.
11.4 @ 125 w/DR500, DR Stage III heads, 50 Shot, Weight reductions, and no traction.
AutocrossPhotobucket
neverenoughhp is offline   Reply With Quote
Old 07-05-2009, 12:50 PM   #13 (permalink)
Well I am not the one that orginally said that a stock GN turbo would be good for 1000hp, I know that it has been done to GN's with lots of work. Someone else mentioned. I was just asking what parts I would need and if a rebuilt 87 gn turbo would be a good size for this project. Selling this one and putting themoney i would spend in parts to getting a tt awd is a possibliity. Like I said still planning and seening what I can do. First thing I need to do though is figure out how much this will cost me. Not too worried about the exhaust and intake fabrication. its more the other stuff.
Old 07-05-2009, 01:59 PM   #14 (permalink)
Drives: 93 VR-4
go back and read post #6. you mis-understood what happened. no one said they gn turbo can handle 1000+ hp.
buick would not put a turbo that size on a stock car.
supporting mods can not create lots of power by them self, you get the power from the turbo forcing air into the engine coupled with the correct amount of fuel and tuning. heads, cams, cam gears, etc only allow the turbo to get more of the air into and out of the engine but if the turbo cant flow enough air those mods will not create much more extra power.
turbo and exhaust sizing is the most important part of your build and adequate fuel and tuning should be a given not an extra "mod"
i am still not exactly sure what you want in the end. if you want just some extra power now and you are certain that you wont want more and you are stuck on a single just to be different i would look for the combined flow rates between two 9bs up to two 15gs and look for a single that would flow that. 850 cfm for example. however you also need to look at what psi the turbo is efficient at and much more. there is a lot of work to go into it that is why i would go with what is already been proven. you could pick up twin 13g or 13cs for cheap.
Old 07-05-2009, 07:21 PM   #15 (permalink)
Ok so he was saying the the GN turbo is for 350 ish and the Precision is for 1000+ Certainly not shooting for 1000+, if I can get 350 ish I would be happy. Like I said all I am asking is if anyone here that has run a single turbo what types of turbos would be well suited to provide a modest amount of boost. Pulling 1000 plus is not what i am after, I don't have the coin to spend on all of the other stuff I would need. When I did a turbo on an fi before we used a megasquirt. Has anyone used one of those in an NA to Turbo project?
Old 07-05-2009, 07:30 PM   #16 (permalink)
Drives: 93 VR-4
yes, i believe mr3000 used a megasquirt for an na to t70
i think you are trying to make this harder than it has to be though. there are countless threads on this forum that show you step by step everything you need for a tt setup and tuning with the stock ecu and a simple safc is really easy. stock 9bs are stupid cheap and can make more than 350 crank horse.
Old 07-05-2009, 07:33 PM   #17 (permalink)
Lots of 9b's around for sale used and rebuilt in the states, but I was having a hard time finding any up here in canada, shipping and duty is retarded and wreckers want like 400 bucks each for them as pulls not rebuilt. If anyone can find me a pair of rebuilt 9b's, manifolds and downpipes for under 350 bucks I am all ears.
No doubt a TT would be easier, just turning stones and kicking tires.
Old 07-05-2009, 07:47 PM   #18 (permalink)
Drives: 93 VR-4
oh, didnt know you were in Canada. well if you could find the exh manifolds you could aslo get 13gs, 13cs, or 15gs but it may be hard to get it for less than 350 however it will be hard to do anything for that amount. when you get into a custom setup one thing is for certain, it will cost more than you think. may want to just save a little more and get a setup you can be happy with for a while.
im just giving you my thoughts. nothing wrong with a single setup. im not providing info on it b/c i have not built a custom setup. do you know how to read compressor maps? do you understand ve and cfm flow ratings? may want to start with an investment in a book or seat time in front of a computer. even search this forum there are guys on here that have done custom singles however most of them are not small budget oriented projects.
Old 07-13-2009, 07:16 PM   #19 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Drives: Mrs. Officer
Ondontii Level 1Ondontii Level 1
Look for parts that match your goals. :P thats what I was saying :P
Brent
1992 Duster 11.54@125 22psi BONE Stock 6g72 12 valve - 12.7@114 14psi boost -516whp 519ft/lb 20psi (Old 3.13L built shortblock) - Precision 6765, Tial 38mm open dump, 3" open downpipe, 20x12x3" evo style intercooler, Stock 10:1 diamante 12 valve shortblock with regapped rings. heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage Racing 278 custom turbo cams, RPW cam gears, Custom Ram Style short runner intake manifold, 12 Gal Jaz Fuel Cell, Dual external Walbro GSL392 255HPs, Dual 5/16" feed lines, Trick Flow AFPR, 3 puck solid hub & 3300# DD plate, OBX Torsional Diff, Zeitronix wideband/EGT/Boost, 2100cc 3 nozzle DevilsOwn Meth. Running on 4.0 BAR Megasquirt II, 47# Inj, E70 Fuel
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
Ondontii is offline   Reply With Quote
Old 07-14-2009, 09:26 AM   #20 (permalink)
Well I decided to go to a TT project with 9b's, found a member on here willing to ship them up to the great white north country. I'll start a new thread on the conversion. I'll be in parts gathering mode now. Thanks for all the input guys.
