Old 06-04-2008, 06:30 AM   #21 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7Ondontii Level 7
Default Re: Single Turbo
Originally Posted by amiturbo View Post
then would a 60-1 give instant spool?
No, it depends on your turbine.
There are .48 .63 .82 turbine housings
There are stage 1, stage II, stage III, and stage V t3 turbine wheels...
and you could build a t4 turbine setup (t4 wheel and housing) if you wanted to.
Just throwing out a compressor wheel size doesnt help much. What matters is the whole package.
You need a turbo that will run right through the middle of the compressor wheel efficiency map, and if the turbine setup is too small, it will surge, if its too big, then it will be overly laggy. If the compressor is too small, then it will run off the right side of the compressor map.
Most people copy what someone else has done that has been proven to work. If you cant copy someone, then you have to be very careful when it comes to turbo selection. Using advice that really doesnt apply to your motor/car is not helpful.
And if you have ever driven a FWD turbo before with 300+hp, then you would know that a turbo building lots of boost in the low RPMs is a horrible idea.
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit.
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
Ondontii is offline   Reply With Quote
Old 06-04-2008, 07:52 AM   #22 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
markoverclock is an unknown quantity at this point
what is your spool up like i have a t76 with p trim divided flange im goin to be using .84 housing. and how much power did you make? ill be using the 46mm wastegate with a 3in downpipe and cutout.
markoverclock is offline   Reply With Quote
Old 06-04-2008, 01:10 PM   #23 (permalink)
I love her▼
Mr.3000's Avatar
Drives: T70 3000GT
Trader Rating: (39)
Mr.3000 Level 7Mr.3000 Level 7Mr.3000 Level 7Mr.3000 Level 7Mr.3000 Level 7Mr.3000 Level 7Mr.3000 Level 7Mr.3000 Level 7Mr.3000 Level 7Mr.3000 Level 7
Sounds pretty sick dude. I don't know who you were referring to with your post but if you are referring to me, I'm not sure yet because I have not finished my build yet. That being said, if my calculations are correct, I should see full boost by about 4K and make quite a bit over 500whp at around 15 to 16psi. With a T76, you are gonna make some monstrous power.
My build should be done within about 30-40 days so I will have more info then.
Project Z11A:My T70 Build
Courtesy of Piedmont Custom Motorsports
Mr.3000 is offline   Reply With Quote
Old 06-04-2008, 02:54 PM   #24 (permalink)
Been here since 01!
HenesseygtoMR's Avatar
Drives: 100 yds downfield
HenesseygtoMR Level 1HenesseygtoMR Level 1
Im watching you ......
Soarer Turbonetics T66.
HenesseygtoMR is offline   Reply With Quote
Old 06-04-2008, 06:10 PM   #25 (permalink)
Banned from Classifieds
Drives: 93 dodge stealth es
amiturbo Negative 1
that's why i'm asking questions....well given what I want basically (instant spool) with around 290-310fwhp. What would you guys advise me to use? (that's probly the more adequate question) I mean ondontii as you know i had my turbo shadow with a garrett t03 ar .48 2.5" swingvalve and turbo talon with 13g,14b,16g...and others on here know about my turbo colts in 14b,16g,18c,and 20g platforms BUT everything turbo i've owned has been 4cyl.
amiturbo is offline   Reply With Quote
