Old 05-13-2008, 07:34 AM   #21 (permalink)
Aaron's Avatar
Drives: 1995 3000gt
Aaron is an unknown quantity at this point
Default Re: Question on O2s
Whats scary is this shop does a lot of work on 3000gt/ stealths. they had 5 there while i was there
1995 3000gt Base, Just completed my engine rebuild and MTX swap
Mods: Long tube headers, 2.5" Magnaflow high flow cat, 2.5" single in dual out Flowmaster 40 series muffler, true cold air intake, throttle body spacer, upper plenum spacer, stage 3 heads, Underdrive pulley, Short throw shifter and more
Ext. Mods: HID headlights, 20% black window tint, 18" black w/chrome lip rims, 245/40/zr18 low profile tires, 2 3.5" chrome exhaust tips
Int. Mods. Jenson in-dash DVD player, Alpine 12 sub, Alpine amp, blue lights
Aaron is offline   Reply With Quote
Old 05-13-2008, 07:41 AM   #22 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Yikes man. I don't know if you should take your car back there, ever.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 05-13-2008, 07:45 AM   #23 (permalink)
VA 3S
Tool Man's Avatar
Drives: 94 3000GT NA
Trader Rating: (27)
Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7Tool Man Level 7
Originally Posted by Hannibalzero View Post
By the way Kevin, I have been driving around on one O2 sensor for almost two weeks now. Still no CEL.
Good news, good news
Pics of my car, click me!_______ August 2006 ROTM
DSM 13Gs, gutted pre-cats, 3" after market downpipe with 3" high flow Cat,Custom 3" stainless steel catback dual exhaust,Modified oil pan & Stainless steel oil return lines,APEXI S-AFC2, Manual Boost Controller, Front and rear Polly mounts. Running waste gate for now ( 7 PSI ) until I get to a Dyno.
Tool Man is offline   Reply With Quote
Old 10-10-2008, 10:11 PM   #24 (permalink)
Drives: Various
slasher48 Level 7slasher48 Level 7slasher48 Level 7slasher48 Level 7slasher48 Level 7slasher48 Level 7slasher48 Level 7slasher48 Level 7slasher48 Level 7slasher48 Level 7slasher48 Level 7
Hi, wanted to see if there have been any updates about running on one sensor or splitting one to both inputs.
I tried splitting one sensor into 2 inputs a few years back on a 2jz-ge, but that didn't work out. Triggered a CEL. Probably b/c of the issues that lawdogg mentioned, but the ecu also controls closed loop fuel individually between 2 "banks" of 3 cyl ea.
Wasn't sure if the 3/S ECU also did separate closed loop fuel trims for the 2 banks, or if a second sensor is just a redundancy feature in case one goes out.
In electronics, we used directional couplers with tap ports to measure lines with negligible impact on the main signal levels, so the 1 into 2 thing probably isn't going to work out because of voltage splitting.
slasher48 is offline   Reply With Quote
Old 10-11-2008, 05:46 AM   #25 (permalink)
VA 3S
Tool Man's Avatar
Trader Rating: (27)
Most people have been splitting and running 2. I've driven around the block a few times with just the one hooked up and haven't thrown one yet. I'm going to start driving it regularly this coming week, so I guess I'll see then.
Old 10-11-2008, 08:54 PM   #26 (permalink)
VR4-GASM's Avatar
Drives: other ppl's cars
Trader Rating: (10)
VR4-GASM Level 4VR4-GASM Level 4VR4-GASM Level 4VR4-GASM Level 4VR4-GASM Level 4
I'm using my NA harness, which only has one O2 sensor. As well as a '91 TT ECU and I haven't had any problems with it. I do have a CEL that came on about 4 days after I finished the conversion.
I'm betting it's from having no cats and/or no EGR. The car runs fine otherwise.
1995 3000GT Base BPU+ (10:1 @ 10psi)
HKS, Apex-i, GReddy, AEM, K&N, Stillen, ACT, 3SX Performance, Maximal Performance, Ground Zero Performance.
*500+ FWHP soon to be in the works*
VR4-GASM is offline   Reply With Quote
Old 10-11-2008, 09:37 PM   #27 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: '93 3000GT ATX TT
Trader Rating: (179)
BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7BigTyla Level 7
I've been running just the rear o2 sensor for over a year. I split it so that the ECU would read two signals. It's been running fine in normal driving but when datalogging my o2 signal drops to 0.05 V at idle and also seems slow to respond when going WOT. This could have something to do with splitting the wire which causes a current drop.
I'll most likely be hooking up a front o2 sensor to compliment the rear. Who knows, maybe my rear o2 is just going bad and it has nothing to do with the wiring.
1993 3000GT FWD ATX TT - mods coming<---------------->2009 Honda Fit - 40 mpg ftw
Nov/Dec ground wire GB!!!
