Old 03-23-2008, 06:13 PM   #1 (permalink)
mike3851 is an unknown quantity at this point
Default Question on engine swap
I have a 97 SL DOHC. what would i need if i swapped engines with a vr4?
mike3851 is offline   Reply With Quote
Old 03-25-2008, 11:48 AM   #2 (permalink)
<>_<>
Blizzind's Avatar
Drives: with lifter tick
Blizzind is an unknown quantity at this point
Default Re: Question on engine swap
Vr4 engine, wiring harness, ecu. If your car is an mtx it should be pretty easy. Mine was alot harder though because i had to convert to an mtx from atx. But that should be about all you'll need to change if you do a direct swap. Get a donor car.
Blizzind is offline   Reply With Quote
