Old 09-21-2009, 02:16 PM   #1 (permalink)
kenarm88's Avatar
Drives: 94gt sl and 97gt
kenarm88 Negative 1
Default Odd Conversion
ok heres what i have. 94 gt cali spec sl. so yes it has the tt ecu. replaced trany from a 94 stealth rt. and a replaced engine from i have no idea from what. the engine is a 2.5 dohc! i cant find any info on the engine other than its the same block as a 3.0 just with a smaller bore and the heads are ported more. its imported from japan. it puts out about 240hp! so with that being said im in the mits of doing a tt conversion i have read the forum and the tt bible. i have all the parts mines some odds and ends bolts. so what yall think? and any words of advice? thanks for the suport
kenarm88 is offline   Reply With Quote
Old 09-21-2009, 02:20 PM   #2 (permalink)
Brapppp!!
Hard AttacK's Avatar
Drives: 95 3000GT SL
Hard AttacK Negative 2
Default Re: Odd Conversion
Pics or it didn't happen.
95 panama green SLow---2.5" maximal performance cat-back+test pipe,3SX lightweight aluminum crank pulley,plenum spacer, HID kit, K&N drop in, 120k service
Originally Posted by Turbo Beast View Post
People who wear crocs out in the open need a good can-o-whoopass
Originally Posted by Import Power View Post
Ethanol only
Only I drive it (wife used to but now it scares her)
Her name is bitch
Hard AttacK is offline   Reply With Quote
Old 09-21-2009, 02:27 PM   #3 (permalink)
No.1 Lurker
Drives: when CA says i can
Trader Rating: (6)
3kgtslme is an unknown quantity at this point
they used these motors in the... ahh what was it again? i want to say legumn vr-4? 2.5L twin turbo...don't really remember but there is a mitsu motor like that.
But the question to ask is, why? why move to a smaller engine when the 6g72 has more displacement?
spun bearing club member # eleventybillion
DR650 build in the works
Originally Posted by Firestorm95RT View Post
Yeah there's a lot of things my car would good with.. but they cost too much to swallow.
For instance, my car would look GREAT with moving pavement under it.
3kgtslme is offline   Reply With Quote
Old 09-21-2009, 02:37 PM   #4 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (134)
Stealthee Level 2Stealthee Level 2Stealthee Level 2Stealthee Level 2Stealthee Level 2Stealthee Level 2
Uh, BULLSHIT.
Besides the 94 Cali Spec SL DOES NOT, have a TT ecu. It has a NA Cali Spec ECU.
The only 2.5 that is compatible is the 6g73 and its a 2.5 SOHC.
The 2.5 DOHC is a completely different line of engines and will not work in a 3s.
Next.
Old 09-21-2009, 02:39 PM   #5 (permalink)
No.1 Lurker
Trader Rating: (6)
Damn that was fast.
Old 09-21-2009, 02:42 PM   #6 (permalink)
ATL
MK_94_3000GT's Avatar
Drives: 94 3000GT 91 3000GT
Trader Rating: (78)
MK_94_3000GT Level 1MK_94_3000GT Level 1
You can plug a TT ecu into a 94 Calispec though. So thats believable.
They would be
MD192588 TT
MD192590 NA
respectively.
They are almost the same and both have the 4 plugs for the ECU. But it does not COME with a TT ECU.
My 94 is set up that way
STEALTH KILLER
Originally Posted by VR-4Madness View Post
To do an awd tt coversion with a new engine costs a lil over 20 g's to do it right, i almost did it. You would have to know cars like the back of your hand to be able to do all of that yourself. Why do you think only a few people have done it?
MK_94_3000GT is online now   Reply With Quote
Old 09-21-2009, 02:52 PM   #7 (permalink)
kenarm88's Avatar
kenarm88 Negative 1
its happening now
Old 09-21-2009, 02:55 PM   #8 (permalink)
kenarm88's Avatar
kenarm88 Negative 1
the engine was inexpensive at the time when i blow mine. and it made more horsepower and the high flow heads i thought would be better for the tt conversion. and it has a 9:1 compression
Old 09-21-2009, 02:56 PM   #9 (permalink)
kenarm88's Avatar
kenarm88 Negative 1
Originally Posted by Stealthee View Post
Uh, BULLSHIT.
Next.
you should do more research. ive had that motor in the car run for over a year.
Old 09-21-2009, 02:57 PM   #10 (permalink)
kenarm88's Avatar
kenarm88 Negative 1
im going to put up pics asap
