#341 (permalink) |
Damn It!
dont think im just pissing in your coffee man. Im just saying research it, This thing is a science, you cant just piece stuff together and expect to run fast. That wont work man.
96 3000GT FWD TT -Rebuilt 2 bolt 8:1 block, balanced stock internals, valve job, 99 Lifters, Maximal Performance Motor mounts and valve cover!! Quaife LSD, ACT Max Extreme 6 puck, RPS flywheel, Greddy emanage Ultimate, custom fuel system i designed my self, profec B spec2, walbro 255lph, stock turbos, Braided steel upper and lower radiator hoses, KNN FPIK, FMIC, FM oil cooler, cusco Oil catch can, stillen DP, IPS 3" single, Full AC delete, stripped interior, Corbeau Forza 2 seat, 2 inch harness, ALL Greddy electronic gauges, brakes: 4 piston calipers from Yogurts TT, Hawk pads, Valvoline DOT 4, Russells steel lines
Coming soon: ![]() Thats right 12G72TT ![]() |
#342 (permalink) | |
Forum user
VR4-"FOR OFF ROAD USE ONLY"
97 FWDTT Mods SOHC to 3.1L TT swap, ATX to 5-SPEED GETRAG, TE04H DR-19T's,Wiseco Forged Pistons, Custom FMIC, RPS MAX Street clutch,Tial BOV, Walbro 255,Custom Magnaflow 3'' exhaust,ATR DP,Custom FMIC,ATR DP,Catless, 3SX crank pulley, Emanage/E01, Derale fan controller, PTE 550 inj, AEM UEGO wideband, Re-located Optima Red Top,Krank Vents, EGR Blockoffs, MMCD logger, Stillen pads, drilled rotors, EibachPro springs, 3SX intake, intake hard pipes, IPO SX AFPR, 99 lifters,99 rear garnish, Racing Hart MP3 wheels,Snow Stg 2D Meth injection/Safe inj, http://www.hesspower.com/racecar.html |
#343 (permalink) |
Resident rocket scientist
You can't just port something and call it a day. Things like that require HOURS of time on a flow bench. Just because it looks pretty doesn't mean it will perform better. You could end up choking the incoming air by making the ports too wide if the heads cannot support the amount of extra air you're letting in! Not to mention that you aren't moving nearly enough air for the stock intake plenum to become noticeably restrictive.
Read this and see for yourself that at this point, you certainly do not need a custom manifold. http://www.popularhotrodding.com/tec...lds/index.html
![]() 1993 3000GT FWD ATX TT - mods coming<---------------->2009 Honda Fit - 40 mpg ftw Topline Engineering ground wire kit Nov/Dec ground wire GB!!! |
#344 (permalink) |
I love her▼
Oh yea yea...I'm sorry I didn't clarify earlier. This plenum thing is a side project. I wasn't going to be putting this on anytime soon. Maybe I should have waited to post it until I was actually done lol. I won't be putting this on for a LONG LONG time. I was just trying to experiment to see what's actually good with this stuff. I know porting is a science and I wasn't trying to screw with anything on my car haha. I just used my stock NA plenum because I wasn't going to get it sold anyway due to the VICS gear being stripped. I will be using the stock TT plenum for a LONG LONG time. This was just an idea I had the other day when I was going thru parts that I needed to sell or throw away. I was planning to finish it one day and then do a dyno pull or two with it on vs the stock plenum just for some laughs. As far as this build goes, I really do want to extract as much power as I can out of it but I don't want to do things wrong either. I believe that the stock intake plenum isn't as efficient as it could be but it is prob alot more efficient than my idea lol.
I am glad however to hear your take on things and I may just end up buying an intake plenum from a vendor. The intake plenum thing is gonna be one of the last "modifications" that I do in an attempt to make my setup more efficient. Dee and 3startuna, I really do respect your opinions especially as they are coming from members who know a heck of alot more than I do and I can see where my design could be lacking and I definitely don't want to waste any money at this time. I was just fooling around haha. As always, thanks for your input guys!!
#346 (permalink) |
Damn It!
yeah man the header would be an easier thing to fab. Really u should flow bench that as well, but u can get away with messing that up easier than with the intake.
As for atermarket intakes i havent seen one thats better than the stocker. Our stocker is actually well designed. Even though it may look retarded. lol |
#347 (permalink) |
I love her▼
Yea I mean for the exhaust manifolds I am just gonna bust out my DN style ones that I bought the other day. I guess I won't even bother with the custom intake manifold. I didn't know that it was that crucial as far as length of runners determining low end torque vs high end hp and size and shape of end tank changing things too. Well I am glad I haven't paid a dime for this idea lol. The whole reason behind this idea was wanting to use the Q45 90mm TB. I guess it really isn't that big of a deal lol.
#348 (permalink) | |
Forum user
-- Alec, your the best sport ever! Not many members can take criticism that well. Honestly with your setup you already have a hell of a FWDTT. Get all the bugs worked out and work on your next real problem- Traction . |
#349 (permalink) | |
I love her▼
As for a little update, I got the stock oil lines so all I am waiting on is the braided nylon hose and I will start tearing the car apart lol. |
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f53/my-tt-project-56k-no-376322/
| Posted By | For | Type | Date | |
| 3000GT Stealth Twin Turbo Conversion Guide/How-to | 3SGuide | This thread | Refback | 04-14-2008 06:37 PM | |
| Thread Tools | |
