#91 (permalink) | |
I love her▼
NEW TT 3" EXHAUST: ![]() OLD NA 2.5" EXHAUST: ![]() Haha..now I just have to muster up enough strength and will power to get the rest of the project done. Peace for now..
#92 (permalink) |
Forum user
LOL- just get her running descent- then be very patient with getting the tune correct. My suggestion is to be conservative and not get too cocky with the tune. I got cocky and melted my #4 piston hehe! My 11:4-11:5 AFR was a beast-- yes it was alittle rich with meth, but perfect on pump gas. I felt alittle indestructable and leaned it to 12:2 on meth-- bye bye motor! (90 octane piss water sucked even with meth LOL). Patients and knowing when to call it good enough will save you more money than geico can brotha.
VR4-"FOR OFF ROAD USE ONLY"
97 FWDTT Mods SOHC to 3.1L TT swap, ATX to 5-SPEED GETRAG, TE04H DR-19T's,Wiseco Forged Pistons, Custom FMIC, RPS MAX Street clutch,Tial BOV, Walbro 255,Custom Magnaflow 3'' exhaust,ATR DP,Custom FMIC,ATR DP,Catless, 3SX crank pulley, Emanage/E01, Derale fan controller, PTE 550 inj, AEM UEGO wideband, Re-located Optima Red Top,Krank Vents, EGR Blockoffs, MMCD logger, Stillen pads, drilled rotors, EibachPro springs, 3SX intake, intake hard pipes, IPO SX AFPR, 99 lifters,99 rear garnish, Racing Hart MP3 wheels,Snow Stg 2D Meth injection/Safe inj, http://www.hesspower.com/racecar.html Last edited by 3000hybrid : 06-26-2007 at 10:56 PM. |
#93 (permalink) |
I love her▼
Hahaha yea at idle last night it was about 11.5-12. As soon as I drove it it (to put it in the garage) it went up to like 15.1 then to 18 then I got - - -. Yea I don't even want to drive my car like this haha. I have 93 octance, what should I be aiming for when I tune it?
#94 (permalink) |
Forum user
Optimum is 14.7 or so idle/cruising. It will fluctuate some, but it's no problem as long as it's like 14.5 thru 15.0. It's super hard to get a perfect 14.7. Aim for 11.4 to 11.5 WOT on 93 octane.Watch for knock! Running rich will lower knock but you are still robbing the car of power. I was at 10.0 or below at first at WOT. By the time I leaned it to 11.0 the car was picking up a whole lot of power and turbos spooled alot faster. Running too rich kills gas mileage and power/hides knock-- running too lean will melt internals. If you can get it down to around 11.0 with no knock you will be very happy and still be very very safe.
First decide the boost you want to run- log a run- check for knock and AFR at WOT- if no knock lean the tune slighly- repeat until you have your target AFR with no knock- if you get knock lower boost and watch AFR-Log WOT again until your happy repeating the steps- Zero knock is safe- leaner AFR is more power. I don't think you have timing control so this is the most you can do at the moment for a descent tune. Last edited by 3000hybrid : 06-27-2007 at 06:29 AM. |
#95 (permalink) | |
Brees-y in the Big Easy
interested in helping out with an established 3S site? pm me
#96 (permalink) | ||
I love her▼
#97 (permalink) | |
Forum user
. If your boost controller takes a crap or you accidently set it too high it could boost or just spike easily into dangerous territory on a 10:1 car. I assure you, you will be pleased with your car at just 8 psi . 10psi will be nuts for torque on that CR. |
#98 (permalink) |
I love her▼
UPDATE 13 - (6/28/07) Well...once again I'm screwed by this project. Yesterday, I decided to investigate my oil leaks. I thought I knew where they were coming from and thought that I was just going in there to fix the problems. So yea I "thought" that the oil was leaking from the TT oil pressure sending unit and adapter. Well that is not the case. Infact, it is leaking from the little unit that is right next to it on the block. I don't even know what the part is called let alone it's part number so I can order another one from Mitsubishi. I guess the problem occurred when I was removing it from the block to gain access to the NA oil pressure sending unit and adapter to replace it with the TT one. I had put this piece back in the dark and thus, thought that it was tight. Since it wasn't tight, it had been leaking oil like a mad man from that spot the whole time. After, trying unsuccessfully to screw the thing back into the block for about 10 mins. I decided to back it out and see what the problem was....well I had mysteriously managed to bend the stud so that it was bent at an angle at about the halfway mark. Ofcourse, this meant that it was not going to go back into the block. So now my car is sitting on block while I wait on an exhaust gasket that z32_aaron so graciously sent me to fix the exhaust leak and as I try to find out what part I broke. Anybody know what this part is. Here are the pics: ![]() ![]() ![]() ![]() If someone could tell me what part that is and or what the part number is for it that would be greatly appreciated. Until then my DD will sit up on jackstands lol. So much for ironing on the bugs in this project. Until I get that part, I can't fix the fuel line leak or any other problems really for that matter. Well this is me signing off for now. Thanks for all the support....ugh this just makes me so mad.... Last edited by Mr.3000 : 08-24-2007 at 04:17 PM. |
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f53/my-tt-project-56k-no-376322/
| Posted By | For | Type | Date | |
| 3000GT Stealth Twin Turbo Conversion Guide/How-to | 3SGuide | This thread | Refback | 04-14-2008 06:37 PM | |
| Thread Tools | |
