John, not looking through this whole thread, so.....Did you keep the radiator with the lines for the auto transmision or did you need to switch it out?
I swapped it out for a Koyo, BUT I didn't trim down my AC lines so I had to swap back in that radiator and have been running it for the last month. The darn AC bolts gouged out a hole in my Koyo and I need to get it welded.
My overheating problems came from my fans, first they ate the fan shroud and were binding up, then the fuse kept on blowing. *knocks on wood* I've gotten all of that worked out and have been perfect for almost 2 months now.
So the Automatic radiator is sufficient for a TT conversion.
I need to read through your thread. I'm not on here enough recently.
woot just read all 59 pages. Very impressive build!
1992 Dodge Stealth R/T TT (41,928 original miles!)
Mods: BROKEN!
1992 Dodge Stealth R/T NA
Mods: 3sx DP, 3sx TP, Ebay Intake, 96 Trans with 30k on it
FOR SALE!
1991 Eagle Talon Tsi
Current weight ~2652
Mods: Ross 9:1 pistons, Eagle Rods, Balanced Bottom End, TRE stage 2.5 trans with a 4 spider gear and a front lsd, SBR 3500 HD clutch kit, Gutted rear, no power steering or a/c, Apexi 3in open downpipe, DSMLink, 264,272 Comp Cams, 2g MAF, 2g Manifold, Open dump tube. AMS 680cc Injectors, Walbro 255, 23 psi .
i read the whole thing... and despite how long it took, and the problems set in front of him, he still finished... and now im ready to start mine. finding parts as we speak!
I have a question for you about your turbo spool with the higher compression. You have a NA engine right? Isnt that 10:1 CR? Do you have any data on the spool with the 13Ts with 10:1?
Thanks for your input,
Rob
Originally Posted by TheZephire
he had a n/a, but after finding a crack in his block he got a tt block and he has 9:1 pistons.
