#1 (permalink) |
VA 3S
I have 13Gs for my conversion and have a SAFC ll. If I use that to control the mixture, do I even need to change out to a TT ECU or would it be just as good using the NA ECU?
#3 (permalink) | |
cyber bully
but I wouldn’t skimp on this part. btw make sure to open it up and inspect for leaking caps Paul
#4 (permalink) | |
VA 3S
I was just wondering. |
#8 (permalink) |
In short, you dont NEED a tt ecu but i would recommend one. It has better fuel maps for high throttle settings on your safc.
I have used an na ecu with a safc and a tt ecu with an safc. You can do either. My experience is that with the n/a ecu, the low throttle settings are very easy to get perfect but the high throttle settings is where it is a little tricky. I actually had to add fuel (and i have 525cc injectors) and then when i started making real power i couldnt add enough fuel. With my tt ecu and safc, My high throttle settings are wonderful. I have to take away a good amount of fuel (like i should have to with bigger injectors) and i still have a ton left if i turn up the boost. But for some reason at idle i need to add all the fuel (50%) i can just to be at 15 afr. THen when i am cruising i am adding a little bit of fuel which is weird because i should be removing alot because of my injector size. But I have it set where it runs perfect but the way that it is set is just a little different than would be expected. If you are looking to make over 350 whp then get the tt ecu for sure. My n/a ecu was fine up to that point, but once i started making more than that, i couldnt add enough fuel. Either way you will have to mess with settings to get everything perfect. If you have a wideband it will help Tremendously.
![]() ![]() 8:1 TT Engine, 93 TT ECU, TEC-17g's, AWD/FWD 5spd Getrag, Spec Stage 3 Clutch, ebay FMIC kit, Precision 525cc Injectors, Apexi S-afc 2, MBC@ 16psi, 3" Stillen Downpipe, 3" Single Exhaust, HKS SSQV bov, AEM UEGO WIdeband, Hotwired supra fuel pump, IPS Y-Pipe, Dejon tool intake pipes Weight = 2860lbs, 396 FWHP, 117.85 trap speed (hks intercooler kit, atx tranny, n/a ecu,front 9b and much more for sale!!) |
#9 (permalink) | |
To the OP, what injectors do you plan to run with the 13g's. |
