Old 04-18-2008, 05:12 PM   #11 (permalink)
TPW Educator
LVA3KGT's Avatar
Drives: therefore he is
LVA3KGT Level 2LVA3KGT Level 2LVA3KGT Level 2
Default Re: If I'm using a SAFC ll do I even need to use a TT ECU?
Originally Posted by Tool Man View Post
Stock TT injectors.
What is your HP/TQ goal?
You don't have to get bigger injectors if you don't want to, but if you want to get the most out of those 13Gs, it is probably a good idea to at least consider a set of 450s. Might want to consider looking at a hotwire kit for your fuel pump too.
To you original question, I can't think of a reason NOT to go with a TT ECU. NA ECUs were designed for NA cars.
97 SLX
World's fastest fwdTT 97SL in Phoenix
410 Ft/lbs of torque-steer and 390HP to the front wheels, making 1-3 gear useless @17psi. Built and tuned by 3SX
First time to the track (Firebird) = Best 60ft 2.4 Best ET 13.8 , best trap 110.4MPH , picked up almost 30mph on the big end of the track.
3SI member # 5422
LVA3KGT is offline   Reply With Quote
Old 04-18-2008, 05:17 PM   #12 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
Run the TT ecu.
The NA ecu is programmed for the stock NA 210 cc inj's. When you correct for anything more than 360 cc inj's (stock vr4 inj's), such as going to 450 cc inj's thats more than 50% correction values and your timing will be very advanced.
Save your self the headache and just run the TT ecu and fine tune with safc2
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 04-18-2008, 05:39 PM   #13 (permalink)
Drives: 94 3000GT SL TT
94ATXVR2 is an unknown quantity at this point
If your going with 360's then definetely the TT ecu will be a great fit and a much easier tune. I thought maybe you were going a little bigger for the 13g's so i gave my input on what my 525's are like. But for sure if you have the tt ecu and its not alot of trouble then use it you will be happy in the long run especially if you ever try to max out your 13g's.
And like kibwe said it will advance your timing IF you have to take away alot of fuel. But i ran 525's on the n/a ecu for 2 years but i had to ADD a ton of fuel. Its weird how the n/a ecu dealt with boost. The tt deals with boost alot better and your high throttle setting will be like they should. So run the TT ecu because if i would have had the chance to run it right away i would have because it is the best option.
8:1 TT Engine, 93 TT ECU, TEC-17g's, AWD/FWD 5spd Getrag, Spec Stage 3 Clutch, ebay FMIC kit, Precision 525cc Injectors, Apexi S-afc 2, MBC@ 16psi, 3" Stillen Downpipe, 3" Single Exhaust, HKS SSQV bov, AEM UEGO WIdeband, Hotwired supra fuel pump, IPS Y-Pipe, Dejon tool intake pipes
Weight = 2860lbs, 396 FWHP, 117.85 trap speed (hks intercooler kit, atx tranny, n/a ecu,front 9b and much more for sale!!)
94ATXVR2 is offline   Reply With Quote
Old 04-18-2008, 09:00 PM   #14 (permalink)
cyber bully
Trader Rating: (7)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
Originally Posted by 94ATXVR2 View Post
Did you really? I have to lean out my high settings (like -25%) and i am at the 400whp mark. And i have to richen up my low throttle. I have 525cc injectors by the way. What are yours? 360's?
To the OP, what injectors do you plan to run with the 13g's.
yes 360s. at idle and just cruising it was rich then at WOT I would knock.
