Old 01-01-2008, 02:55 PM   #11 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: 03 350Z, 93 ATX TT
Trader Rating: (192)
BigTyla Level 1BigTyla Level 1
Default Re: How to use a TT ECU in your TT ATX
This thread needs a sticky. I get so many PMs from ATX guys wanting to do this and they don't even know this thread exists.
2003 Nissan 350Z Track Edition 6MT<------------------------->2009 Honda Fit - 40 mpg ftw
1993 3000GT FWD ATX TT - FOR SALE - $4000 OBO
BigTyla is online now   Reply With Quote
Old 01-03-2008, 09:43 AM   #12 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (56)
Hannibalzero is an unknown quantity at this point
Or a Wiki.
Old 02-10-2008, 09:45 PM   #13 (permalink)
BigTyla's Avatar
Bumping because I get questions about this almost weekly. I believe this is also on the wiki, but if I am mistaken please let me know.
Old 02-11-2008, 12:16 AM   #14 (permalink)
H to the izzO
Drives: Recklessly
Trader Rating: (56)
Hey T, here's a question: did you try plugging in the TT ECU without modifying the wiring? If so, what were the results? I did this today on my NA 2G harness, and it drove around the block fine. Logging and (I assume) radiator fans were not available.
Old 04-14-2008, 01:51 PM   #15 (permalink)
BigTyla's Avatar
Bump because I have received multiple questions about this within the past few weeks.
Admins: please sticky this so it is easier to find! Not everyone visits the wiki, and quite frankly the wiki isn't quite as easy to navigate as the forums.
Old 04-14-2008, 01:53 PM   #16 (permalink)
H to the izzO
Drives: Recklessly
Trader Rating: (56)
Bah, you never answered my question.
Old 04-14-2008, 02:11 PM   #17 (permalink)
Banned from Classifieds
Drives: 93 dodge stealth es
amiturbo Negative 1
bump this thread needs a sticky seriously...thanks tyler i needed this bad!
amiturbo is offline   Reply With Quote
Old 04-14-2008, 02:14 PM   #18 (permalink)
Don't go green!!
Trader Rating: (33)
green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2
I will put this on the TT conversion thread. I hope that helps.
The American dream is not a birthright
http://www.3si.org/forum/f4/speed-fr...insert-468314/
green-lantern is online now   Reply With Quote
Old 04-14-2008, 02:15 PM   #19 (permalink)
amiturbo Negative 1
i spent weeks searching for this thread again lol and tyla had to send me the link lol
Old 04-14-2008, 02:39 PM   #20 (permalink)
BigTyla's Avatar
Ah damn, I didn't see it.
Yes, I did. It burned my ECU. One of the pins in the TT ECU is a ground assignment. If you do not modify the wiring, a powered wire (starter relay signal wire) will be plugged into that ground assigment, which will pop the ECU. You will still be able to drive it, but some of the functions (in my case my TPS sensor was not functioning correctly as a result) will not be working properly.
If this was just something I experienced in a freak accident, it still would not work properly since your timing would be at around 5 degrees like mine was for so long. Log your car like that next time and see if you have similar timing.
