Old 03-27-2009, 05:09 PM   #11 (permalink)
VR4-GASM's Avatar
Drives: an STi
Trader Rating: (11)
VR4-GASM is an unknown quantity at this point
Default Re: How To: E85 Conversion
Originally Posted by Gushers248 View Post
If my pump outflows the need for that much line pressure without a hotwire, why hotwire it? My understanding was that because e85 needs 30% more fuel to burn correctly. and 360 x 1.30 is 468 and 450cc is 4% off which a 4% difference isn't a bad tune stock with the ecu right? or is that not how you tune?
Math...
Hopefully someone can chime in about this.
1995 3000GT FWD Twin Turbo
16psi, 450s, E85
13.52 @ 110.56 with a 2.17 60'...13psi.
332FWHP-342TQ...16psi with many boost leaks.
SOLD 8-09 :-(
2005 Crystal Gray Metallic STi
*not stock*
VR4-GASM is offline   Reply With Quote
Old 04-06-2009, 02:32 PM   #12 (permalink)
Don't go green!!
Trader Rating: (33)
green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2
Your math is correct but you will need some way of fine tuning. You will be in the ball park but not in play.
The American dream is not a birthright
http://www.3si.org/forum/f4/speed-fr...insert-468314/
Old 04-07-2009, 06:56 PM   #13 (permalink)
Drives: 1997 TSi AWD 6 Bolt
uhlig is an unknown quantity at this point
30% is incorrect, it's around 20%. It's not E100 we are talkin' about here.
I would not run E85 without at least an SAFC2 and Wideband 02, since it's not always as straight forward as calculations. They'll get you close but you really need to jump in and find out what's best for you by actually using real time feedback via the WB02.
I run 780cc injectors and I have my car PLUS 17% to make it idle correctly, just a weird litle quirk that I found to be true with other cars running E85 as well. Even with say 450cc injectors, you will still need to richen it up around 15-20% or so at idle to see proper A/Fs.
1997 TSi
6 bolt
272's
E85
33PSI
Daily driven transmission eater.
uhlig is offline   Reply With Quote
Old 04-08-2009, 10:34 AM   #14 (permalink)
Don't go green!!
Trader Rating: (33)
Thanks for the info man.
I started to sign up for the DSM forum yesterday and between the image verification and the stupid question on my 6th attempt I said fuck it. I hate those GD things! I will try again later when I have more patience.
