Old 10-21-2007, 02:33 PM   #1 (permalink)
Resident rocket scientist
BigTyla's Avatar
Drives: 03 350Z, 93 ATX TT
Trader Rating: (192)
BigTyla Level 1BigTyla Level 1
Default Help me with spark plug gap
I'm running a stock TT conversion at 6 psi on NGK coppers BCP7ES, so they are the correct heat range. What gap are you guys running? I'm running the gap specified in the manual : .040. I'm getting a lot of knock under boost and suspect that this may be due to my spark plug gap as some helpful people have pointed out in another thread.
Any help is appreciated.
2003 Nissan 350Z Track Edition 6MT<------------------------->2009 Honda Fit - 40 mpg ftw
1993 3000GT FWD ATX TT - FOR SALE - $4000 OBO
Old 10-21-2007, 09:49 PM   #2 (permalink)
Forum user
3000hybrid's Avatar
Drives: 93 VR4, 04 350ZR
Trader Rating: (49)
3000hybrid is an unknown quantity at this point
Default Re: Help me with spark plug gap
I run .028 gap with NGK's one step colder. I get spark blow out badly at anything above .032. With a smaller gap your idle won't be quite as perfect as stock gap, but it should drive and boost fine.
93 VR4 (under the knife)
97 FWDTT (Getting parted)
Mods
3.1L TE04H DR-19T's,Wiseco Forged Pistons, Custom FMIC, RPS MAX Street clutch,Tial BOV, Walbro 255,Custom Magnaflow 3'' exhaust,ATR DP,ATR DP,Catless, 3SX crank pulley, Emanage/E01, Derale fan controller, PTE 550 inj, AEM UEGO wideband, Re-located Optima Red Top,Krank Vents, EGR Blockoffs, MMCD logger, Stillen pads, drilled rotors, EibachPro springs, 3SX intake, intake hard pipes, IPO SX AFPR, 99 lifters,99 rear garnish, Racing Hart MP3 wheels,Snow Stg 2D Meth injection/Safe inj, http://www.hesspower.com/racecar.html
3000hybrid is offline   Reply With Quote
Old 10-22-2007, 12:22 AM   #3 (permalink)
I love her▼
Mr.3000's Avatar
Drives: T70 3000GT
Trader Rating: (43)
Mr.3000 is an unknown quantity at this point
3000 Hybrid is right. I run .030 so yea somewhere between 0.028 and .032 and you should be fine. Also how are your SMIC's doing? If they are getting heat soaked then that could also be contributing to the knock. I am going FMIC cuz I am tired of dealing with heatsoak, boost leaks and all that rubber tubing lol.
Mr.3000 is offline   Reply With Quote
Old 10-22-2007, 01:04 PM   #4 (permalink)
BigTyla's Avatar
I am running the stock FMICs but I don't think heat soak is the problem since the knock occurs even when the motor is cold (albeit even more when it is warm).
I don't know - .030 seems pretty small for a stock conversion on 6 psi. I was considering trying .035ish which is a little smaller than the minimum suggestion in the shop manual.
Old 10-22-2007, 04:27 PM   #5 (permalink)
J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3J-Groove Level 3
I'd say go at least .030. I'm running on .030 right now and debating dropping down to .028.
Old 10-22-2007, 04:37 PM   #6 (permalink)
Cabana Boy
vr4operator's Avatar
Drives: People CRAZY!
Trader Rating: (20)
vr4operator Level 1vr4operator Level 1
NGK's at .028. I had Iridiums at .031 and that worked, but I had tried .035 previously and got blowout at high boost. gotta tell yeah, first time it happened, scared the bejesus outta me....
"Got Turbo? Meet The Twins"
Car Domain Link
In NY? 3S Motors
In MA? Enhance Street Performance
My '71 Stingray and '94 VR4 .......Proud to continue my 16+ years of honorable service to my country
Pampena Stage 1 block, 15T's, 550cc inj's, Walpro 255, K&N kit, and more...
vr4operator is offline   Reply With Quote
Old 10-22-2007, 06:20 PM   #7 (permalink)
BigTyla's Avatar
Well hell, if that's what's working for you guys I guess I'll try it as well. It just seems so small.
Old 07-20-2008, 01:00 PM   #8 (permalink)
og
chansigril's Avatar
Drives: 93 stealth rt tt
Trader Rating: (48)
chansigril Level 2chansigril Level 2chansigril Level 2chansigril Level 2chansigril Level 2
i run my plugs gapped at .030, any larger and at 15+ psi blowout occurs. this is with 13t's. currently coppers, once i get done tuning i'll be changing to the ngk irridium ix's and the gap will stay the same, .030.
93 dodge stealth r/t tt: mildly modified, 12.4@109
94 dodge stealth r/t na: used to drive, 13.9@100
93 dodge stealth r/t tt: personal parts car
98 honda passport ex: winter 4wd beater
03 ford focus se: beater
chansigril is offline   Reply With Quote
Old 07-21-2008, 10:50 AM   #9 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (56)
Hannibalzero is an unknown quantity at this point
Tyla, on 6psi I'd say shoot for .035. If you still get blowout, regap it down to .032 and try again. On 6psi, I run one step colder NGKs at .040 without blow out.
Old 07-21-2008, 10:55 AM   #10 (permalink)
Don't go green!!
Trader Rating: (33)
green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2
Old thread my friend. I put the link in someone’s thread that wanted help with gap and someone posted in it.
The American dream is not a birthright
http://www.3si.org/forum/f4/speed-fr...insert-468314/
