Old 03-17-2008, 07:12 PM   #11 (permalink)
VA 3S
Tool Man's Avatar
Drives: 94 3000GT FWD TT
Trader Rating: (38)
Tool Man Level 1Tool Man Level 1
Default Re: A Guide for connecting a 1G TT ECU to a 1G/2G NA harness
Ok, I have a question. I'm in the middle of my conversion on my 94. Using a 1st Gen TT ecu and my 94 NA harness. The TT conversion car I'm using for the donor has a 1 O2 setup on it. The only o2 sensor is the rear one. The fron O2 Bung has a bolt in it. It's using the first gen tt ecu and harness. Should this work ok?
Tool Man is online now   Reply With Quote
Old 03-17-2008, 08:06 PM   #12 (permalink)
I love her▼
Mr.3000's Avatar
Drives: T70 3000GT
Trader Rating: (43)
Mr.3000 is an unknown quantity at this point
I would run the two TT O2 sensors because the TT ecu is expecting two signals.
Mr.3000 is offline   Reply With Quote
Old 03-17-2008, 11:00 PM   #13 (permalink)
Don't go green!!
Trader Rating: (33)
green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2
oh yes! I would definitely use both O2 sensors. That is very strange that the donor only had one (could have been its demise)
The American dream is not a birthright
http://www.3si.org/forum/f4/speed-fr...insert-468314/
Old 03-18-2008, 11:16 PM   #14 (permalink)
Don't go green!!
Trader Rating: (33)
updates TM, you really ought to start a thread.
Old 06-15-2009, 08:56 AM   #15 (permalink)
Don't go green!!
Trader Rating: (33)
Mr 3000, Please explain your edit.
**WHEN EXTENDING O2 WIRES, DO NOT SOLDER TWO WIRES TOGETHER! THE SIGNAL WILL NOT READ CORRECTLY! INSTEAD USE CONNECTORS**
I don't understand why that matters. I soldered mine so I need to change mine if it does.
Thanks
btw they have changed the way the fan controller is wired up. I just installed a new one this weekend. I can post up the difference and you can add it to the first post in your thread if you want to do that.
Old 06-15-2009, 01:50 PM   #16 (permalink)
I love her▼
Mr.3000's Avatar
Drives: T70 3000GT
Trader Rating: (43)
Thanks
Yes the only wires that you should never solder together are O2 sensor wires. Why? Well the signal actually gets destroyed by the solder which is really crazy. Yea I didn't figure this one out until after my car broke and the guys up at PCM saw that I had soldered them together. It is actually mostly a little known fact that solder messes up the signal.
I remember that whenever I tried to datalog using the stock O2 sensors, I was getting crazy numbers from them that weren't fluctuating properly and I never could figure out why. So I tuned off of my wideband instead and just had to deal with not being able to verify the results from my datalog. Little did I know that this would still cause problems from time to time because the factory ECU is still reading from those sensors and trying to compensate for what it is seeing and thus my tune would be off a lot of the time.
The way to remedy this is to use crimp connectors. Then once you connect them, wrap the connection so that it can never come loose.
Old 06-15-2009, 02:31 PM   #17 (permalink)
Don't go green!!
Trader Rating: (33)
It seemed like mine where working correctly (cycling) but also I have always felt like there has been something a little off. It could just be my imagination but anyway I will redo it and see what happens.
Thanks!!!
Old 09-23-2009, 10:09 PM   #18 (permalink)
Forum user
levani041491's Avatar
Drives: 1996 3000GT&1991 vr4
Trader Rating: (7)
levani041491 Negative 1
i am getting to that and i have 1996 CALI-spec and it will be same ?? on body it says august 1995 and title says 1996 and i f i get 1G FED ECU can i use in cali-spec?
levani041491 is offline   Reply With Quote
Old 09-26-2009, 12:49 AM   #19 (permalink)
Lohnes68's Avatar
Drives: 94' 3KGT
Lohnes68 is an unknown quantity at this point
i also have a question here. I have a 94 fed spec NA, if i put a TT 94 fed. ecu in the car do i need to change any wires or will it plug right in?
Lohnes68 is offline   Reply With Quote
Old 09-27-2009, 05:19 AM   #20 (permalink)
I love her▼
Mr.3000's Avatar
Drives: T70 3000GT
Trader Rating: (43)
I'm actually not sure about this one. I haven't seen a Stock 3/S ECU in a long time haha. I do remember that the 96+ ECU's didn't seem to be compatible with the 1st Gen's because they had a different number of connectors. I would locate your ECU and find out if you have 3 or 4 ECU connections before proceeding any further. Also, due to the fact that you have a Cali Spec, I would err on the side of safety and go with a Cali ECU.
No, this will not work. 94+ TT ECU's have 4 connections. Your harness only has 3. The only ECU's that are compatible that will allow minimal modification are the 91-93 TT's. Also, make sure you grab a Fed Spec
