Old 06-22-2009, 07:02 PM   #1 (permalink)
Finally A TT!!!
VillasenorStealth's Avatar
Drives: a banana
Trader Rating: (7)
VillasenorStealth is an unknown quantity at this point
Default Getrag on NA engine
Will any getrag transmission mate up to my 94 na engine? Just making sure before i go ahead and purchase one.
VillasenorStealth is offline   Reply With Quote
Old 06-22-2009, 09:00 PM   #2 (permalink)
Pro Bearing Spinner
Comp-U-Geek's Avatar
Drives: 93 3k, 2x Subie
Trader Rating: (9)
Comp-U-Geek is an unknown quantity at this point
Default Re: Getrag on NA engine
Yep it will bolt right up. The bolt patterns are the same, but you will need to change your trans mount and axles. You will also need the TT flywheel and clutch. There may be more, I just dont remember right now.
Chris
TX07 - 1st Place Fastest NA
TX07 - 1st Place Most NA WHP
NG08 - 1st Place AutoX FWD Stock
TX08 - 1st Place Quickest NA
TX08 - 1st Place Highest HP NA
NG09 - 1st Place AutoX FWD Stock
NG09 - 1st Place Drags FWD
TX09 - 1st Place Quickest NA
TX09 - 1st Place Highest HP NA
10/24/2009 - 220WHP 222WTQ (6g74, 93.5mm bore, ported heads, stock 3L cams, open DP )
02/17/2007 - 14.700 @ 96.1mph (3.5 with everything else stock at the time)
03/22/2008 - 14.644 @ 94.48 (drag radials, 3.5 on crappy tune with upgraded fuel system)
Comp-U-Geek is offline   Reply With Quote
Old 06-22-2009, 10:49 PM   #3 (permalink)
Finally A TT!!!
Drives: a banana
Trader Rating: (7)
Chris
Alright awesome thank you
