Old 04-22-2008, 08:54 AM   #21 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (53)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Default Re: FWD-TT Is it possible to...
The way I see it, if it was absolutely imperative that each bank see exactly the same amount of pressure/flow, then mitsu wouldn't have stuck a turd-shaped manifold in the front. We would end up with two near identical manifolds that would allow both banks to flow evenly. Keep in mind that the precats are different as well - I suspect the rear one has better flow. Based on how the exhast was engineered, I am going to assume that subtle differences between each bank probably won't spell disaster.
Big differences on the other hand...
Originally Posted by cbehnken View Post
There is a benefit though. Whenever someone is selling a single turbo cheap you can pick one up and always pick up another later.
DR650s do not spool like 13Ts. If I had two DR650s I know it would be laggier than my 13Gs. I now have a combo of the lag with more top end.
I also have probably $400-450 in both turbos combined. I really don't know how you can beat that for a combination that should hold 20 PSI (or close) to redline.
If you can find turbos that cheap, then you might as well run them. Since they are both TD04 based housings, I don't think there is a big enough difference to cause significant pressure difference between banks (assuming they are both within their efficiency range). Now if one was a TD05 or T4 turbo... that would give me cause for concern.
This engine has 142K on it, but still runs perfect. If it failed tomorrow I could hardly be mad at it. Stock rings and pistons yet, good compression yet and perfect oil pressure now. This engine also ran a 9b/13G for a LONG time.
174k on matching turbos. Suck it.
Hannibalzero is online now   Reply With Quote
Old 04-22-2008, 08:56 AM   #22 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
LOL, I'll catch you someday!@ In about 20 years at this rate if you stop driving alltogether!
Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops MAXED out, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, 17" chromies, Nitto 555s
Drivetrain: RPS Street Max, M.W. 300m O/S
Etc: Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
JEDI MASTER SAFC NARROWBAND BASED TUNER, LORD OF THE DANCE ALSO
cbehnken is offline   Reply With Quote
Old 04-22-2008, 10:23 AM   #23 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7Kibwe Walker Level 7
194k on matching turbos here
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
Hers - BPU Green 94 vr4
Kibwe Walker is offline   Reply With Quote
Old 04-23-2008, 09:06 PM   #24 (permalink)
LAS VEGAS
pantherchams's Avatar
Drives: 92 RT/TT,91 XJ
pantherchams is an unknown quantity at this point
just to throw it out there, i have about 25K on my 9b/15g. My 15g is in the front. I like it. feels basically like stock except the car still pulls after 6k.
Ben
1992 Red Stealth RT/TT
-Installed:
15G/9b combo @15psi, K&N Intake, Gutted Precats, RFL BOV, MC Datalogger, 550cc, SAFC-2, Boomslang Harness, horribly bent and discontinued Borbet type TS 18X8.5 with kumho ecstas, Wet Okole Seat Covers, Tein S-techs, lots of dumb people door ding mods
pantherchams is offline   Reply With Quote
