Old 06-27-2009, 05:45 PM   #801 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Default Re: FWD TT cars.. how many are there now?
Fun daily car. No overheating issues. reliability.
I would get a full TT conversion.
TT engine or put 8-8.5 pistons in your NA block
TD04 turbos of your choice.
SIDE MOUNT intercoolers, DSMs work great.
3SX Aluminum Single pass radiator
NOT flexalite fans - stock fans!
AWD 5 spd trans converted for FWD.
TT ECU
SAFC or MAFT or both or Emanage blue (ultimate complicates things but works great)
DONE.
Just re read you have ATX. Cooler (you have) and make sure to get a FAN for the cooler. Heat kills ATXs. I would send the torque converter to hughes in AZ and have it restalled and brazed for more power.
-Chris
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-770AWHP 747AWTQ 30psi E100 Daily Driver 10.57@136mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Import Power is online now   Reply With Quote
Old 06-27-2009, 05:47 PM   #802 (permalink)
Minty
Alt0id's Avatar
Drives: '94 3000GT SL
Trader Rating: (10)
Alt0id Level 1Alt0id Level 1
Whats wrong with 10:1? Lower boost, but as long as I stick it lower I shouldn't have problems w/ reliability, no?
edit: fan for my trans cooler? hmmm never heard of doing that. Just throwing it mounted in front won't do the trick?
steven@il3s.com
1994 Mitsubishi 3000GT SL Twin Turbo
10:1 - 9b turbos - 93 Twin Turbo ECU - MR downpipe - KN FIPK - 360cc injectors - Prosport Wideband - Prosport Boost gauge - Plenum Spacer - ATX
--Soon to come
13t turbos, 450cc injectors, e85, apexi safc, boost controller, getrag, FMIC,
Alt0id is offline   Reply With Quote
Old 06-27-2009, 05:51 PM   #803 (permalink)
Idea is not a race car but a fun get around daily.
Any suggestions?
I want reliability. Budget is a concern, but not deciding factor on most things.
10:1 works. But if you want it to be more reliable go lower compression. If something were to happen, bad gas, overboost, hot day, overheated IC, whatever...8:1 gives you more leeway.
You want to stay under budget, find 1st gen TT pistons, the top ring land is thicker than 2nd gens which gives better chance of not cracking under detonation.
-Chris
Old 06-27-2009, 06:12 PM   #804 (permalink)
Minty
Alt0id's Avatar
Trader Rating: (10)
Hmm I see your point.. I'll have to take this into some serious consideration
Old 07-17-2009, 10:14 PM   #805 (permalink)
VR4-GASM's Avatar
Drives: an STi
Trader Rating: (11)
VR4-GASM is an unknown quantity at this point
Originally Posted by Import Power View Post
All this hype, this long ass list, and not ONE FWDTT at the drags at NG09...
What is up with that???
-Chris
If I didn't need VSS I would have seriously considered going. My car smokes like a mofo.
1995 3000GT FWD Twin Turbo
16psi, 450s, E85
13.52 @ 110.56 with a 2.17 60'...13psi.
332FWHP-342TQ...16psi with many boost leaks.
SOLD 8-09 :-(
2005 Crystal Gray Metallic STi
*not stock*
VR4-GASM is offline   Reply With Quote
Old 08-11-2009, 12:56 AM   #806 (permalink)
Drives: '96 black SL TT
johnthomas is an unknown quantity at this point
Add me to the TT conversion list..... John Thomas 1996 Black SL TT
Black '96 3000gt sl TT
johnthomas is offline   Reply With Quote
Old 08-11-2009, 01:29 AM   #807 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 1Kibwe Walker Level 1
So whats the actual number if anyone is counting?
I have my stock manifolds, 9b's, stock SMIC's, and stock DP if anyone is considering doing the conversion.
Red 93 RT/tt project car
Mods: stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, dsm SMIC's, Tein S springs, pte 580 inj's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
94 vr4: RIP 4/16/09
Kibwe Walker is offline   Reply With Quote
Old 08-11-2009, 02:52 PM   #808 (permalink)
Don't go green!!
Trader Rating: (33)
green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2green-lantern Level 2
-Chris
Well there was one there I really wish I would have run now but some issues were keeping me paranoid to run it at the time. Well I guess if I would have run and tore it up I would be sitting here wishing I didn’t run.
The American dream is not a birthright
http://www.3si.org/forum/f4/speed-fr...insert-468314/
Old 08-11-2009, 03:52 PM   #809 (permalink)
TONER WINCH
R3KGT's Avatar
Drives: FWDATXTT
R3KGT is an unknown quantity at this point
FWD TT ATX at 10-12psi is a hoot. I have driven a few. Fun stuff.
-Chris
This is what I have been telling people for the past two years when they try to convince me to go with a 5 speed.
These cars are a blast to drive with this setup.
Granny
It took 20 years for me to make a man of my son and another woman makes a fool of him in twenty minutes.
R3KGT is offline   Reply With Quote
Old 08-11-2009, 07:25 PM   #810 (permalink)
Minty
Alt0id's Avatar
Trader Rating: (10)
Granny
What are you running in it?
